| HTTP Request [message #926573] |
Fri, 28 September 2012 15:41  |
Nathan Reed Messages: 74 Registered: June 2012 |
Member |
I am integrating some BIRT report function.
I need to post a URL to initiate the creation of a PDF.
Is there a simple way to load a URL in EGL?
There is no web page in this case but now I realize I have not had the need to just load a web page while in EGL. I assume there is a way but I am just not finding it.
Thx,
Nathan Reed
| Re: HTTP Request [message #929703 is a reply to message #929182] |
Mon, 01 October 2012 13:26   |
Dan Darnell Messages: 145 Registered: November 2011 Location: Arkansas |
Using BiRT here with EGL in RBD and it works very well. We're not actually using the interface that allows you to code EGL as a means of providing data to BiRT reports. Rather, we just design BiRT reports using its own tools but invoke those reports out of EGL as desired. I haven't tried doing background report creation though (ours always pop up the generated report on the client system).
Here's our RBD implementation:
Property used to somewhat soft-code the server reference...
reportRoot=http://www.myserver.com/birt/frameset?__report=
External type used to launch report in new window...
launch Launch {};
launch.openWindow(Properties.reportRoot, reportName);
External type details...
externalType Launch extends Widget type JavaScriptObject {
relativePath = "com/xxxxxx/custom/widgets",
javaScriptName = "Launch" }
function openWindow(host string in, path string in) returns(boolean);
end
egl.defineClass(
'com.xxxxxx.custom.widgets', 'Launch',
"openWindow" : function (host, path) {
var windowUrl=host+escape(path);
m = window.open(windowUrl,'newwindow','resizable=yes');
return true;
| Re: HTTP Request [message #930580 is a reply to message #929703] |
Tue, 02 October 2012 08:59  |
Member |
Dan:
Thx much. I spent a lot of time in RBD getting the EGL interface working and did not get much out of it. Nice to know what others are doing.
Nathan Reed
FUDForum. Page generated in 0.02050 seconds
