| ActiveMQ Integration [message #930481] |
Tue, 02 October 2012 07:07  |
Alex Bond Messages: 1 Registered: October 2012 |
Junior Member |
Hey guys!
I'm trying to integrate ActiveMQ into my Virgo server. Is there a common way to just drop in the jar (or something like that) without writing any line of code? Just out of the box.
Furthermore, it should be configurable. I've seen the karaf example at the activeMQ page (where it creates a XML file and you just modify it). Is there something similar for the virgo server?
Thanks a lot,
Alex
| Re: ActiveMQ Integration [message #933916 is a reply to message #930481] |
Fri, 05 October 2012 09:06   |
I integrated activemq in Virgo, you just have to make a little bundle containing the amq configuration, here's mine (it just embed a META-INF/spring/activemqconf.xml:
<beans xmlns="http://www.springframework.org/schema/beans"
xmlns:amq="http://activemq.apache.org/schema/core"
xmlns:osgi="http://www.springframework.org/schema/osgi"
xmlns:context="http://www.springframework.org/schema/context"
xmlns:osgi-compendium="http://www.springframework.org/schema/osgi-compendium"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="
http://www.springframework.org/schema/osgi http://www.springframework.org/schema/osgi/spring-osgi.xsd
http://www.springframework.org/schema/osgi-compendium http://www.springframework.org/schema/osgi-compendium/spring-osgi-compendium.xsd
http://www.springframework.org/schema/beans http://www.springframework.org/schema/beans/spring-beans.xsd
http://www.springframework.org/schema/context http://www.springframework.org/schema/context/spring-context.xsd
http://activemq.apache.org/schema/core http://activemq.apache.org/schema/core/activemq-core.xsd">
<osgi-compendium:cm-properties id="jmsConfigProperties" persistent-id="jms-config"/>
<context:property-placeholder properties-ref="jmsConfigProperties"/>
<amq:broker brokerName="brokerB1" shutdownOnMasterFailure="true"
<amq:destinationPolicy>
<amq:policyMap>
<amq:policyEntries>
<amq:policyEntry queue=">" producerFlowControl="true"
memoryLimit="5mb">
<amq:deadLetterStrategy>
<amq:individualDeadLetterStrategy
queuePrefix="DLQ." useQueueForQueueMessages="true" />
</amq:deadLetterStrategy>
</amq:policyEntry>
</amq:policyEntries>
</amq:policyMap>
</amq:destinationPolicy>
<amq:managementContext>
<amq:managementContext createConnector="false" />
</amq:managementContext>
<amq:persistenceAdapter>
<amq:kahaDB directory="activeMQ/kahadb"
enableJournalDiskSyncs="false" indexWriteBatchSize="10000"
indexCacheSize="1000" />
</amq:persistenceAdapter>
<amq:plugins>
<amq:loggingBrokerPlugin />
</amq:plugins>
<amq:systemUsage>
<amq:systemUsage>
<amq:memoryUsage>
<amq:memoryUsage limit="420 mb" />
</amq:memoryUsage>
<amq:storeUsage>
<amq:storeUsage limit="1 gb" />
</amq:storeUsage>
<amq:tempUsage>
<amq:tempUsage limit="250 mb" />
</amq:tempUsage>
</amq:systemUsage>
</amq:systemUsage>
<amq:transportConnectors>
<amq:transportConnector name="tcp"
uri="${transportconnector.uri}" />
</amq:transportConnectors>
</amq:broker>
<!-- JMS ConnectionFactory to use, configuring the embedded broker using
XML -->
<amq:connectionFactory id="jmsFactory" brokerURL="${connectionfactory.uri}" />
<bean id="cachedConnectionFactory"
class="org.springframework.jms.connection.CachingConnectionFactory">
<property name="targetConnectionFactory" ref="jmsFactory" />
<property name="sessionCacheSize" value="3" />
</bean>
<osgi:service ref="cachedConnectionFactory"
interface="javax.jms.ConnectionFactory"/>
</beans>
With this, you can have a jms-config.properties in your usr repo:
transportconnector.uri=tcp://0.0.0.0:61616
connectionfactory.uri=vm://localhost
Then you should be able to reference the amq connectionfaction via service reference (blueprint, spring-dm...).
Charlie
[Updated on: Fri, 05 October 2012 09:09] Report message to a moderator
| Re: ActiveMQ Integration [message #1000022 is a reply to message #933916] |
Sun, 13 January 2013 15:05   |
Miguel Salinas Gancedo Messages: 6 Registered: October 2012 |
Junior Member |
Hi Charlie,
I was trying to follow your example with Virgo 3.0.2. I create the bundle like you and add the necesary bundles to my virgo instance and create the properties file called jms-config.properties and save it in:
/opt/virgo-tomcat-server-3.0.3.RELEASE/repository/usr directory
And i obtaind the error:
... Could not resolve placeholder 'transportconnector.uri'
That you see i cant not recover the properties from the file throw spring. I also save the file in the /opt/virgo-tomcat-server-3.0.3.RELEASE/repository/usr/config directory and the error it's the same.
If I add default values to the properties configuration the system run ok, but if not I obtained the previous error:
<osgi-compendium:cm-properties id="jmsConfigProperties" persistent-id="jms-config">
<prop key="transportconnector.uri">tcp://0.0.0.0:61616</prop>
<prop key="connectionfactory.uri">vm://localhost</prop>
</osgi-compendium:cm-properties>
Where I must save the properties file inside Virgo?
Best regards.
[Updated on: Sun, 13 January 2013 15:27] Report message to a moderator
FUDForum. Page generated in 0.02797 seconds
