Home » Newcomers » Newcomers » Eclipse seg fault 11 OSX
Eclipse seg fault 11 OSX [message #930389] Tue, 02 October 2012 05:14 Go to next message
Austin Reid is currently offline Austin Reid
Hi, I have used eclipse without major problem for years on both Window and OSX.
However today I clicked the 'You have updates' on my Juno 64 bit eclipse on OSX Lion 10.8.2.
Java version is:
java version "1.6.0_35"
Java(TM) SE Runtime Environment (build 1.6.0_35-b10-428-11M3811)
Java HotSpot(TM) 64-Bit Server VM (build 20.10-b01-428, mixed mode)
Updates installed to eclipse, seemingly ok and asked to restart eclipse.
Eclipse began restarting, thrashing my CPU 100% until after 5 minutes I killed the process. The splash had disappeared, no UI, but the dock icon was still there.
Attempts to restart the app resulted in OutOfMemory errors:
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2012-10-02 10:11:52.704
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.workbench.swt".
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2012-10-02 10:11:56.859
!STACK 0
java.lang.IllegalArgumentException: Argument cannot be null
at org.eclipse.swt.SWT.error(SWT.java:4342)
at org.eclipse.swt.SWT.error(SWT.java:4276)
at org.eclipse.swt.SWT.error(SWT.java:4247)
at org.eclipse.swt.widgets.Widget.error(Widget.java:775)
at org.eclipse.swt.widgets.Widget.checkParent(Widget.java:506)
at org.eclipse.swt.widgets.Widget.<init>(Widget.java:132)
at org.eclipse.swt.widgets.Control.<init>(Control.java:116)
at org.eclipse.swt.widgets.Scrollable.<init>(Scrollable.java:73)
at org.eclipse.swt.widgets.Composite.<init>(Composite.java:91)
at org.eclipse.e4.ui.workbench.renderers.swt.SashRenderer.createWidget(SashRenderer.java:135)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:896)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:630)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:732)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:703)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:697)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:682)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.createElement(PartServiceImpl.java:1024)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:989)
at org.eclipse.ui.internal.WorkbenchPage.showPart(WorkbenchPage.java:1229)
at org.eclipse.ui.internal.WorkbenchPage.busyShowView(WorkbenchPage.java:1182)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.java:3774)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage.java:3771)
at org.eclipse.ui.internal.ide.IDEWorkbenchPlugin$2.run(IDEWorkbenchPlugin.java:382)
at org.eclipse.swt.widgets.Display.timerProc(Display.java:4697)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5455)
at org.eclipse.swt.internal.cocoa.OS.objc_msgSendSuper(Native Method)
at org.eclipse.swt.widgets.Display.applicationNextEventMatchingMask(Display.java:4873)
at org.eclipse.swt.widgets.Display.applicationProc(Display.java:5239)
at org.eclipse.swt.internal.cocoa.OS.objc_msgSend(Native Method)
at org.eclipse.swt.internal.cocoa.NSApplication.nextEventMatchingMask(NSApplication.java:94)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3613)
at org.eclipse.swt.widgets.Display.release(Display.java:3682)
at org.eclipse.swt.graphics.Device.dispose(Device.java:190)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:140)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-10-02 10:11:56.860
!MESSAGE Exception occurred while rendering: org.eclipse.e4.ui.model.application.ui.basic.impl.PartSashContainerImpl@7b6bb7d9 (elementId: null, tags: [], contributorURI: null) (widget: null, renderer: org.eclipse.e4.ui.workbench.renderers.swt.SashRenderer@6cb59850, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (horizontal: true)
!STACK 0
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2012-10-02 10:11:56.868
!STACK 0
at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:68)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.createElement(PartServiceImpl.java:1027)
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-10-02 10:11:56.869
!MESSAGE Exception occurred while rendering: org.eclipse.e4.ui.model.application.ui.advanced.impl.PlaceholderImpl@530ce397 (elementId: org.eclipse.ui.views.ProblemView, tags: [], contributorURI: null) (widget: null, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer@571f0759, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (closeable: false)
!STACK 0
!ENTRY org.eclipse.osgi 4 0 2012-10-02 10:11:59.312
!MESSAGE Application error
!STACK 1
java.lang.OutOfMemoryError: PermGen space
!ENTRY org.eclipse.osgi 4 0 2012-10-02 10:12:01.204
!STACK 0
!ENTRY org.eclipse.osgi 4 0 2012-10-02 10:12:03.520
!MESSAGE Shutdown error
!STACK 1
!ENTRY org.eclipse.osgi 4 0 2012-10-02 10:12:04.713
!STACK 0
And also this :
Exception in thread "Thread-7" java.lang.OutOfMemoryError: PermGen space
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1205)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:522)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryIO$Parser.parse(MetadataRepositoryIO.java:209)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryIO.read(MetadataRepositoryIO.java:63)
at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.load(SimpleMetadataRepositoryFactory.java:107)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:57)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:758)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:651)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository.addChild(CompositeMetadataRepository.java:165)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository.<init>(CompositeMetadataRepository.java:105)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepositoryFactory.load(CompositeMetadataRepositoryFactory.java:122)
at org.eclipse.equinox.internal.p2.updatechecker.UpdateChecker.getAvailableRepositories(UpdateChecker.java:150)
at org.eclipse.equinox.internal.p2.updatechecker.UpdateChecker.checkForUpdates(UpdateChecker.java:128)
at org.eclipse.equinox.internal.p2.updatechecker.UpdateChecker$UpdateCheckThread.run(UpdateChecker.java:72)
Exception in thread "main" java.lang.OutOfMemoryError: PermGen space
Exception in thread "[Timer] - Main Queue Handler" java.lang.OutOfMemoryError: PermGen space
I then decided to just download Juno again but starting a clean version results in an immediate:
Segmentation fault: 11
Can anyone help?
2 hours ago I was running eclipse ok, all I did was update??????
Thanks.
Re: Eclipse seg fault 11 OSX [message #931781 is a reply to message #930389] Wed, 03 October 2012 10:15 Go to previous message
Martin Hollerweger is currently offline Martin Hollerweger
I had the same Problem.
I solved it by putting a new eclipse.ini under: Eclipse.app/Contents/MacOS/eclipse.ini
and increased the perGem there:
eclipse.ini:
--launcher.XXMaxPermSize
256m
--launcher.defaultAction
openFile
-vmargs
-Dosgi.requiredJavaVersion=1.5
-XstartOnFirstThread
-Dorg.eclipse.swt.internal.carbon.smallFonts
-XX:MaxPermSize=256m
-Xms40m
-Xmx512m
-Xdock:icon=../Resources/Eclipse.icns
Previous Topic:Problem with Scout Tutorials
Next Topic:Eclipse.ini VM / JAVA_HOME Settings
Current Time: Sun May 19 19:03:05 EDT 2013
Powered by FUDForum. Page generated in 0.01663 seconds
