Home » Language IDEs » CDT » disabling cdt code analysis programmatically(disabling cdt code analysis programmatically)
disabling cdt code analysis programmatically [message #916889] Wed, 19 September 2012 11:51 Go to next message
tony burton is currently offline tony burton
I would like to disable cdt code analysis programmatically and, after lots of research and stepping through code, I have found the following:
           CodanPreferencesLoader codanPreferencesLoader = new
                      CodanPreferencesLoader(CodanRuntime.getInstance().
                      getCheckersRegistry().getDefaultProfile());
		IProblem[] probs = codanPreferencesLoader.getProblems();
		for (int i = 0; i < probs.length; i++) {
			String id = probs[i].getId();
			((IProblemWorkingCopy) probs[i]).setEnabled(false);
which seems to work, but when I open the preference page, the values are unchanged.
Could someone please point me in the right direction,
Thanks in advance,
Antony
Re: disabling cdt code analysis programmatically [message #917942 is a reply to message #916889] Thu, 20 September 2012 11:25 Go to previous messageGo to next message
OK, I've realized I was barking up the wrong treeEditor! Now I think I should be doing something like this:
// enable auto save...
IPreferenceStore iwp = 	IDEWorkbenchPlugin.getDefault().getPreferenceStore();
boolean val4 = iwp.getBoolean("SAVE_ALL_BEFORE_BUILD");
iwp.putValue("SAVE_ALL_BEFORE_BUILD", "true");
...which works well for this preference. I found the "SAVE_ALL_BEFORE_BUILD" by steping through the code. In the method get of the class ImmutableMap in org.eclipse.core.internal.preferences, there is an array called keyTable with strings corresponding to the various preferences of the preferenceStore concerned.
But I am unable to find the boolean value of preferences for the code analysis page. I would ideally like to find the id to the boolean which switches off all of the problem checkers (Potential Programming Problems) but search as I might, I cannot.
In the CodanCorePlugin keyTable I can find the individual problem checkers such as "Assignment To Itself" but when I do:
IEclipsePreferences codanp = CodanCorePlugin.getDefault().getStorePreferences();
String val3 = codanp.get("org.eclipse.cdt.codan.internal.checkers.AssignmentToItselfProblem", "");
...it returns the property for this checker (info, error or warning). What is the id for the enable button?
So now I'm getting a little stuck and any help would be greatly appreciated!
Antony
Re: disabling cdt code analysis programmatically [message #929388 is a reply to message #917942] Mon, 01 October 2012 08:15 Go to previous messageGo to next message
It's been almost 2 weeks now since I posted this question. Could someone please give me a pointer, even if it's a link to somewhere I can get an answer,
Antony
Re: disabling cdt code analysis programmatically [message #929890 is a reply to message #929388] Mon, 01 October 2012 17:31 Go to previous messageGo to next message
Yevgeny Shifrin is currently offline Yevgeny Shifrin
I would suggest posting your question on CDT mailing list (https://dev.eclipse.org/mailman/listinfo/cdt-dev). This forum is more for CDT users, CDT mailing list is for CDT developers.
Yevgeny
Re: disabling cdt code analysis programmatically [message #930353 is a reply to message #929890] Tue, 02 October 2012 04:30 Go to previous messageGo to next message
Hi Yevgeny,
Thanks for the info!
Antony
Re: disabling cdt code analysis programmatically [message #1012530 is a reply to message #930353] Thu, 21 February 2013 13:34 Go to previous messageGo to next message
NINGAREDDY MODASE is currently offline NINGAREDDY MODASE
There is way we can enable/disable cdt code analysis settings programmatically
I have used it and it works fine for me.
E.g.
IEclipsePreferences codanp = CodanCorePlugin.getDefault() .getStorePreferences();
codanp.put("org.eclipse.cdt.codan.internal.checkers.VariableResolutionProblem","-Error"); // To disable we have to pass -Error
// To enable we have to pass Error
I have attached the file which contains preferances id'd and their default values
Note: You have to add the dependency 'org.eclipse.cdt.codan.core' in your plugin for controlling preferances settings...
Hope this will help..
Re: disabling cdt code analysis programmatically [message #1012532 is a reply to message #917942] Thu, 21 February 2013 13:39 Go to previous messageGo to next message
Please see the following link. I have replied it.
http://www.eclipse.org/forums/index.php/r/reply_to/930353/
Re: disabling cdt code analysis programmatically [message #1012922 is a reply to message #930353] Fri, 22 February 2013 08:13 Go to previous messageGo to next message
Thank you so much NINGAREDDY! I had found a temporary solution which was to set all problem checkers to 'INFO':
// no code analysis (for the time being I am changing all the problem properties to info (no errors or warnings)...
String[] keys = null;
try {
  keys = codanp.keys();
} catch (org.osgi.service.prefs.BackingStoreException e) {
  e.printStackTrace();
for (int i=0; i<keys.length; i++) {
 if (!keys[i].contains("params"))
	codanp.put(keys[i], "Info");
But I never found that I should put '-' in front to deselect them,
Thanks again,
Antony
Re: disabling cdt code analysis programmatically [message #1012988 is a reply to message #1012922] Fri, 22 February 2013 10:17 Go to previous messageGo to next message
...just another thing that could be of help. In order to disable the problem checkers but keep their default values (Error, Warning or Info), one can do as follows:
	String res = codanp.get(keys[i], "");
	if (!res.substring(0,1).equals("-")) {
		res = "-"+res;
	if (res.equals("-Error") || res.equals("-Warning") || res.equals("-Info")) {
		codanp.put(keys[i], res);
Re: disabling cdt code analysis programmatically [message #1032816 is a reply to message #1012532] Wed, 03 April 2013 09:19 Go to previous message
Hi again!
I have a new problem, up until now, disabling code analysis worked fine, but when I tried using it in a fresh workspace, it didn't work anymore. In order for it to work, one must go into code analysis preferences and press the "Apply" button. So it seems something must be initialized. Have you or anyone any ideas please,
Antony
Previous Topic:How to get warnings for undeclared functions
Next Topic:Jni application error Javaw.exe -Application error?
Current Time: Wed May 22 13:34:48 EDT 2013
Powered by FUDForum. Page generated in 0.02324 seconds
