Home » Modeling » Ecore Tools » Ecore editor doesn't find a file
Ecore editor doesn't find a file [message #930345] Tue, 02 October 2012 04:21
Alexey Romanov is currently offline Alexey Romanov
When I try to open an ecore file referenced from an Xtext grammar, the EMF editor throws a FileNotFoundException:
java.io.FileNotFoundException: Xbase.ecore (No such file or directory)
	at java.io.FileInputStream.open(Native Method)
	at java.io.FileInputStream.<init>(FileInputStream.java:120)
	at org.eclipse.emf.ecore.resource.impl.FileURIHandlerImpl.createInputStream(FileURIHandlerImpl.java:105)
	at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterImpl.createInputStream(ExtensibleURIConverterImpl.java:350)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1262)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:255)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:270)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:397)
	at org.eclipse.emf.ecore.presentation.EcoreEditor.createModelGen(EcoreEditor.java:1062)
	at org.eclipse.emf.ecore.presentation.EcoreEditor.createModel(EcoreEditor.java:1082)
	at org.eclipse.emf.ecore.presentation.EcoreEditor.createPages(EcoreEditor.java:1147)
	at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:348)
	at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:670)
	at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
	at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
	at org.eclipse.ui.internal.EditorReference.getEditor(EditorReference.java:289)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2945)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2850)
	at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2842)
	at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2793)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2789)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2773)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2756)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:439)
	at org.eclipse.xtext.ui.editor.LanguageSpecificURIEditorOpener.open(LanguageSpecificURIEditorOpener.java:81)
	at org.eclipse.xtext.ui.editor.LanguageSpecificURIEditorOpener.open(LanguageSpecificURIEditorOpener.java:70)
	at org.eclipse.xtext.ui.editor.GlobalURIEditorOpener.open(GlobalURIEditorOpener.java:68)
	at org.eclipse.xtext.ui.editor.hyperlinking.XtextHyperlink.open(XtextHyperlink.java:26)
	at org.eclipse.jface.text.hyperlink.MultipleHyperlinkPresenter$LinkListInformationControl.openSelectedLink(MultipleHyperlinkPresenter.java:367)
	at org.eclipse.jface.text.hyperlink.MultipleHyperlinkPresenter$LinkListInformationControl.access$1(MultipleHyperlinkPresenter.java:359)
	at org.eclipse.jface.text.hyperlink.MultipleHyperlinkPresenter$4.mouseUp(MultipleHyperlinkPresenter.java:335)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:219)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3588)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3209)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
But there is also an "Open with Text Editor" button which does open the file without problems. Is the problem that the file is inside a plugin .jar?
Previous Topic:Persisting ecore model in DB takes too long time!!!
Next Topic:Trouble installing/using Ecore Tools SDK
Current Time: Tue May 28 11:04:31 EDT 2013
Powered by FUDForum. Page generated in 0.01560 seconds
