Home » Eclipse Projects » Test and Performance Tools Platform (TPTP) » TPTP idle(unable to undersand servicelog messages)
TPTP idle [message #929141] Mon, 01 October 2012 04:54 Go to next message
Jean Le Fur is currently offline Jean Le Fur
I try to profile an application with TPTP. The profiler starts ok however, it soon becomes idle.
The servicelog.log display tenths of message of the kind below.
is there any direction where I can search for the problem ?
sincerely,
Jean
message form servicelog.log :
<CommonBaseEvent creationTime="2012-10-01T08:42:18.234000Z" globalInstanceId="AA62FE87CD3C44B0A9FA566BCAC02938" msg="Socket: Failed to send data on connection ID 5014" severity="50" version="1.0.1">
<sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=".\SocketListener.c, line 1458" instanceId="1000" location="d7400_jlefur" locationType="IPV4" processId="5292" subComponent="Socket TL" threadId="4712" componentType="Eclipse_TPTP"/>
<situation categoryName="ReportSituation">
<situationType xmlns:xsi="www.w3.org/2001/XMLSchema-instance" xsi:type="ReportSituation" reasoningScope="INTERNAL" reportCategory="LOG"/>
</situation>
</CommonBaseEvent>
Re: TPTP idle [message #929275 is a reply to message #929141] Mon, 01 October 2012 06:34 Go to previous message
Heiner Westphal is currently offline Heiner Westphal
Hello Jean,
looks like the Agent Controller cannot send its data back to eclipe.
Does the log contain any hint, which port is used by "connection ID
5014"? This would be the one to open firewall wise.
If not, look into the service config in
$TPTP_DIR/config/serviceconfig.xml.
From your log I guess the disfunctional port is configured like this:
<TransportLayer loadlib="socketTL" type="TPTP_SOCKET">
This may be a firewall issue.
Hope this helps a bit,
Heiner
Am 01.10.2012 10:54, schrieb Jean Le Fur:
> Hello,
> sincerely,
> Jean
> </situation>
> </CommonBaseEvent>
Previous Topic:string index error when launching app within TPTP profiler
Next Topic:Error is throwing while run the test classes, Run as JUnit
Current Time: Sat May 25 03:28:41 EDT 2013
Powered by FUDForum. Page generated in 0.01552 seconds
