Home » Eclipse Projects » BIRT » How to show or enable/disable parameters depending other parameters?
icon5.gif  How to show or enable/disable parameters depending other parameters? [message #929249] Mon, 01 October 2012 06:11 Go to next message
Blaine Mising name is currently offline Blaine Mising name
I want to do a report for show products list.
How can I enable/disable or hide/show a paremeter depending other parameter value?
For example, I want to show in the parameters window, a parameter list box containing all the brands. If the user selects a brand of the list box, all prodcuts will be shown in the report, but if the user selects the empty value of the list box, I want to show/enable a parameter in which user can put the id of a product, then only the product
How Can I do it?
[Updated on: Mon, 01 October 2012 07:19]
Report message to a moderator
Re: How to show or enable/disable parameters depending other parameters? [message #929668 is a reply to message #929249] Mon, 01 October 2012 12:50 Go to previous message
Jason Weathersby is currently offline Jason Weathersby
By default the BIRT Viewer parameter boxes will not do this. You either have to modify them or create your own parameter box. You could do a cascaded parameter that list all brands in a drop down and depending what the user chooses a second level in the cascade will show different values. This approach means that the end use will always see both parameters though.
Jason
Jason Weathersby
BIRT Exchange
Previous Topic:Birt - Oracle forms
Next Topic:BIRT Chart Drill-Through issue with Scripted Data Source
Current Time: Tue May 21 15:44:15 EDT 2013
Powered by FUDForum. Page generated in 0.03066 seconds
