Home » Eclipse Projects » Eclipse 4 » Logger-Layout?
Logger-Layout? [message #928693] Sun, 30 September 2012 18:26 Go to next message
David Reichl is currently offline David Reichl
I've just started using juno, and I'm trying to get used to die model (and of course with DI). For the beginning I injected a Logger (org.eclipse.e4.core.services.log.Logger) and it's working fine! Now I'm wondering how I could change the layout of the log-messages.? How can I do this? Is there a way like the properties-file in log4j?
Thanks!
Re: Logger-Layout? [message #929110 is a reply to message #928693] Mon, 01 October 2012 04:28 Go to previous messageGo to next message
Christoph Keimel is currently offline Christoph Keimel
Hi David
You can register your own ILoggerProvider as an OSGi service. This way you can choose your own logging framework (log4j, slf4j, ...).
Greetings
Christoph
Re: Logger-Layout? [message #955149 is a reply to message #929110] Tue, 23 October 2012 10:58 Go to previous messageGo to next message
thanks for the answer...maybe I'm justed little bit confoused but how can register a Provider as an OSGi service?
Re: Logger-Layout? [message #955154 is a reply to message #955149] Tue, 23 October 2012 11:00 Go to previous messageGo to next message
<<nonsense>>
[Updated on: Tue, 23 October 2012 11:09]
Report message to a moderator
Re: Logger-Layout? [message #956075 is a reply to message #955149] Wed, 24 October 2012 04:14 Go to previous messageGo to next message
Hi David,
this is how I register an ILoggerProvider which uses slf4j as logging framework.
public class MyPlugin implements BundleActivator {
	private ServiceRegistration<?> registration;
	public void start(BundleContext bundleContext) throws Exception {
	    // Use SLF4J as LoggerProvider for e4
	    ILoggerProvider logService = new ILoggerProvider() {
	    	public org.eclipse.e4.core.services.log.Logger getClassLogger(Class<?> clazz) {
	    		return new Slf4jLoggerWrapper(LoggerFactory.getLogger(clazz));
	    registration = bundleContext.registerService(ILoggerProvider.class, logService, null);
	public void stop(BundleContext bundleContext) throws Exception {
		registration.unregister();
		registration = null;
Greetings
Christoph
[Updated on: Thu, 25 October 2012 05:14]
Re: Logger-Layout? [message #956293 is a reply to message #956075] Wed, 24 October 2012 07:46 Go to previous messageGo to next message
Brian de Alwis is currently offline Brian de Alwis
Note: if you do this via a declarative service, then OSGi will activate your bundle on demand.
Re: Logger-Layout? [message #956896 is a reply to message #956293] Wed, 24 October 2012 18:08 Go to previous messageGo to next message
thanks for your help! i know i'm a greenhorn but i'm trying to get use to eclipse...
just to be sure: the important thing is the "return new Slf4jLoggerWrapper(LoggerFactory.getLogger(clazz));".
so when i get this right i could create a LogFactory which returns a self-made Log4JLogger which extends org.eclipse.e4.core.services.log.Logger and where i have my "private org.apache.log4j.Logger log". in this Log4JLogger i implement for example the method "info" like this:
	public void info(Throwable t, String message) {
		if (this.isInfoEnabled()) {
			this.log.info(buildLogMessage(message, null), t);
could that work?
[Updated on: Wed, 24 October 2012 18:39]
Re: Logger-Layout? [message #956950 is a reply to message #956896] Wed, 24 October 2012 19:09 Go to previous messageGo to next message
it works!
thank you for the help!
[Updated on: Wed, 24 October 2012 19:09]
Re: Logger-Layout? [message #959601 is a reply to message #956950] Fri, 26 October 2012 17:11 Go to previous messageGo to next message
hi,
I just changed my Logger so I can use a log4j-Logger and to use simple "@Inject Logger log" without define the class by my self.
My first thought was:
@Creatable
public class Logger extends org.eclipse.e4.core.services.log.Logger{
	private org.apache.log4j.Logger log = null;
	protected static char sign = '#';
	@Inject
	@SuppressWarnings("unchecked")
	public Logger(@Active MContribution contribution) {
		String uri = contribution.getContributionURI();
		String[] uriArray = uri.split("\\.");
		String uriClass = uriArray[uriArray.length-1];
		this.log = org.apache.log4j.Logger.getLogger(uriClass);
But is this well written? Is there anotherway to get the class?
Re: Logger-Layout? [message #960629 is a reply to message #959601] Sat, 27 October 2012 13:08 Go to previous message
A few comments:
  • Injection will fail if there's no MContribution available. You can use @Optional to avoid that so that the injector will inject "null" if not found.
  • But remember that the injector will normally traverse up the context hierarchy to resolve values. So your MContribution may in fact come from the injection-requestor's ancestor instead. You may choose to be injected with the IEclipseContext instead: you can then request local resolution of different values within that context.
  • I don't remember the scoping of @Creatable: IIRC the Creatable instance is remembered for that context and its descendants. So it you request a Logger from the MApplication, then that single logger instance will be used for all windows & parts. If you instead provide a context function (either declaratively through an OSGi Declarative Services, as an OSGi Service, or by registering a ContextFunction object with a context), you can compute and return a result on each injection: the value returned isn't placed into the context unless your context function explicitly places it into the context.
Previous Topic:Tootip for a TreeViewer
Next Topic:Manually triggering a class with injections?
Current Time: Sat May 18 16:39:31 EDT 2013
Powered by FUDForum. Page generated in 0.01950 seconds
