Home » Eclipse Projects » Gemini » Best practice - gemini jpa
Best practice - gemini jpa [message #913445] Sat, 15 September 2012 13:21 Go to next message
Florian Pirchner is currently offline Florian Pirchner
Member
Hi together,
right now i am wondering about the best practice using gemini jpa and
how other projects are using it.
Question to projects that already use gemini:
How are you using gemini jpa?
- Did you turn off dynamic weaving?
- Or did you change the startorder of the bundles a way, that gemini jpa
does not have to re-resolve the persistence unit?
- Or are you handling the re-resolving internally?
Would be really interesting for me. Then i get an idea what will be best
practice and how i can use it.
Thanks a lot for any hints and discussions...
Best,
Florian
Re: Best practice - gemini jpa [message #928563 is a reply to message #913445] Sun, 30 September 2012 15:19 Go to previous message
Nepomuk Seiler is currently offline Nepomuk Seiler
Member
For my Eclipse RCP and e4 Apps;
Yeah. I turn it off completely and always set the -DREFRESH_BUNDLES=false property.
I tried and always do, but not sure if it helps.
Never tried, but the Eclipse Extension Point handling is hard to change. Things may be a lot easier with e4.
Previous Topic:Gemini DBAccess 1.1.0 Milestone 3
Next Topic:Performance and concurrency of calls into services
Current Time: Sun May 19 15:59:23 EDT 2013
Powered by FUDForum. Page generated in 0.04931 seconds
