Home » Eclipse Projects » JFace » JFace TreeViewer refresh problem
JFace TreeViewer refresh problem [message #927946] Sun, 30 September 2012 01:38 Go to next message
Rameshwar Nagpure is currently offline Rameshwar Nagpure
i want to display parent and child elements using JFace TreeViewer.
When I am displaying parent and child all at once, its working fine.
But I want the child to be added only after expanding the parent element.
The refresh() method is working fine when
ISelectionChangedListener.selectionChanged()
method is called,
but gives error on calling TreeListener.treeExpanded() method
treeStatute.addTreeListener(new ITreeViewerListener() {
			public void treeExpanded(TreeExpansionEvent event) {
[Updated on: Sun, 30 September 2012 03:29]
Report message to a moderator
Re: JFace TreeViewer refresh problem [message #928032 is a reply to message #927946] Sun, 30 September 2012 03:55 Go to previous message
Sandeep Yohans is currently offline Sandeep Yohans
the same logic should execute for both select and expand.
Previous Topic:JFace TreeViewer refresh problem
Next Topic:Reevaluate syntax highlighting for entire document
Current Time: Thu May 23 23:08:30 EDT 2013
Powered by FUDForum. Page generated in 0.02904 seconds
