Home » Eclipse Projects » Jubula » Object Mapper - manually editing the properties of a technical object
Object Mapper - manually editing the properties of a technical object [message #926297] Fri, 28 September 2012 10:01 Go to next message
Thomas Schreckenbach is currently offline Thomas Schreckenbach
A word first.
Jubula is a nice tool that we use intensively to test our web applications.
But - in my opinion a training is a prerequisite for the meaningful use of this tool (e.g. in-house training).
Now to my request...
I agree with the suggestions in the discussion "HTML: Manually specify component id and/or xpath".
Jubula is not yet able to detect a series of objects in complex components. It would be very helpful to have the following options (expert mode):
  • Support of HTML IDs, regular expressions / XPath elements. Selenium provides this capability.
  • The ability to edit the properties of a technical object (in the object mapper). Patching the XML Export Files is not what I want.
    The configuration parameter "id attribute name" is not (not flexible) very helpful.
Best regards, Thomas
Re: Object Mapper - manually editing the properties of a technical object [message #938917 is a reply to message #926297] Wed, 10 October 2012 05:18 Go to previous messageGo to next message
Felix Ziesel is currently offline Felix Ziesel
Hi Thomas,
I think this is an issue you can add as a feature request to https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Jubula.
You can get professional in-house training by the Bredex if you think it will boost your productivity.
Felix
Re: Object Mapper - manually editing the properties of a technical object [message #939036 is a reply to message #938917] Wed, 10 October 2012 07:20 Go to previous message
Hi Felix,
I'll add a feature request.
We got an effective training before we started to use Jubula productive. I think that pays off.
Regards, Thomas
Previous Topic:How to start AUT between the test cases automaticlly
Next Topic:backing up Jubula
Current Time: Fri May 24 17:34:58 EDT 2013
Powered by FUDForum. Page generated in 0.01552 seconds
