Home » Language IDEs » CDT » Include library is not getting listed under Project Explorer for C/C++ project in Juno with CDT 8.1(Include library is not getting listed under Project Explorer for C/C++ project in Juno with CDT 8.1)
Include library is not getting listed under Project Explorer for C/C++ project in Juno with CDT 8.1 [message #893632] Wed, 04 July 2012 23:42 Go to next message
vishwaroop srivastava is currently offline vishwaroop srivastava
Hello Everybody,
I have created a tool chain with tools as compiler, linker and some other tools. so here the problem is, when I add any library from Include option, which comes under Compiler tool. Or if i add any library from Include path and Symbols Property page, I can see newly added library in Project Explorer under Includes for my C/C++ projects when i Use Eclipse Helios or Indigo. But with Eclipse Juno with CDT 8.1 I am having this problem. when you go to Project Property Page -> C/C++ Build -> Tools -> here for Compiler include option, you can see the newly added library listed. But not in project explorer. I don't know why here in this case behavior is different for my C/C++ projects. I can not see this problem with, CDT's local C/C++ project, . Can anybody please tell me what i am doing wrong. or is there any setting which i have to change ?
Re: Include library is not getting listed under Project Explorer for C/C++ project in Juno with CDT [message #922595 is a reply to message #893632] Tue, 25 September 2012 02:36 Go to previous messageGo to next message
Daniel Savard is currently offline Daniel Savard
Have you resolved your problem. I am having the same problem. Since I moved to Juno, the IDE is just a big nightmare. What happened? I am struggling to use it and about to simply drop Eclipse for C++ development.
I just don't see where this is going. I am using this IDE to simplify my life, but I ended up investing time searching where to setup things without finding anything. Where are the old menus? How is it supposed to be organized? I am completely lost with this new CDT plugin.
EDIT: Okay! I found my problem. Need to select Executable at project creation rather than the default.
[Updated on: Tue, 25 September 2012 02:58]
Report message to a moderator
Re: Include library is not getting listed under Project Explorer for C/C++ project in Juno with CDT [message #926063 is a reply to message #922595] Fri, 28 September 2012 05:11 Go to previous message
My problem is resolved now. can you please explain in detail, in which scenario you are facing this problem ?
Previous Topic:CDT Plugin build
Next Topic:Print message in console view
Current Time: Sat May 18 07:05:42 EDT 2013
Powered by FUDForum. Page generated in 0.01675 seconds
