| Re: Why I need to add some .jar to the Java Build Path ? [message #925497 is a reply to message #925335] |
Thu, 27 September 2012 15:32  |
The EMF's EMF ecore XMI plugin isn't on your plugin's "required" plugins
list. You probably have the EMF resources plugin in required list (or
inherited from a required plugin that exported it). They are different
plugins. You don't need to have both as a required, and if you don't
require it then it won't be available.
Or if you are doing straight non-Eclipse java you have resources jar in
your classpath already (or inherited it through a pre-req export).
Rich
FUDForum. Page generated in 0.01568 seconds
