Home » Modeling » ATL » ADT in RCP application
ADT in RCP application [message #916333] Tue, 18 September 2012 18:46 Go to next message
El Arbi Aboussoror is currently offline El Arbi Aboussoror
Member
I need to have the ADT inside my RCP app. What are the plugins or features I need to add to my product feature ?
Re: ADT in RCP application [message #916642 is a reply to message #916333] Wed, 19 September 2012 05:11 Go to previous messageGo to next message
Hugo Bruneliere is currently offline Hugo Bruneliere
If you want to include the full ADT, you should include the ATL features (and referenced plugins) as provided with the Eclipse Simultaneous Releases.
If you just want your RCP app to run some predefined ATL transformations, then including the ATL VM (and corresponding required core plugins) should be sufficient.
Hugo
Hugo Bruneliere - R&D Engineer
AtlanMod research team (Inria, EMN & LINA)
Ecole des Mines de Nantes
Nantes - France
Re: ADT in RCP application [message #925314 is a reply to message #916642] Thu, 27 September 2012 11:51 Go to previous message
Member
Thank you Hugo, I'll try and possibly be back.
Previous Topic:ATL Plugin with 2 source metamodels
Next Topic:[ATL] model element references in input model
Current Time: Fri May 24 09:15:36 EDT 2013
Powered by FUDForum. Page generated in 0.01515 seconds
