| Cannot install PDT as plugin in Eclipse Classic 4.2 [message #925234] |
Thu, 27 September 2012 10:16  |
Luis Martin Messages: 5 Registered: September 2012 |
Junior Member |
Hello, I'm new to Eclipse, just played a little in the past, but I generally used: Dreamweaver on my first years, next Netbeans, finally PHPDesigner. I'd like to try Eclipse PDT seriously, but I opted to install the classic app and then install PDT and Aptana as plugins.
So, I've just installed Eclipse Classic 4.2 (Juno) on Windows 7 (32-bits), and next tried to download and install PDT (PHP Development Tools (PDT) Runtime Feature 3.1.1.201209241501) through Help/Install New Software... getting this error:
Cannot complete the install because one or more required items could not be found.
Software being installed: PHP Development Tools (PDT) Runtime Feature 3.1.1.201209241501 (org.eclipse.php.feature.group 3.1.1.201209241501)
Missing requirement: PDT UI Plug-in 3.1.1.201209241501 (org.eclipse.php.ui 3.1.1.201209241501) requires 'bundle org.eclipse.dltk.core.manipulation 0.0.0' but it could not be found
Cannot satisfy dependency:
From: PHP Development Tools (PDT) Runtime Feature 3.1.1.201209241501 (org.eclipse.php.feature.group 3.1.1.201209241501)
To: org.eclipse.php.ui [3.1.1.201209241501]
Could you please help me solve this problem?
| Re: Cannot install PDT as plugin in Eclipse Classic 4.2 [message #953661 is a reply to message #948037] |
Mon, 22 October 2012 08:30   |
Junior Member |
No idea about this issue? It would be a pity not to be able to properly use Eclipse for PHP, since I like it a lot how the GUI looks.
Now I'm using Netbeans, which is very powerful, but I don't like its GUI somewhat.
I also used phpDesigner 8 trial and I liked it a lot in the way that it provides plenty of code assistance, but I found it a bit buggy to purchase it. And Nusphere phpEd is extremely powerful but I consider it too expensive.
[Updated on: Mon, 22 October 2012 08:30] Report message to a moderator
| Re: Cannot install PDT as plugin in Eclipse Classic 4.2 [message #962683 is a reply to message #956143] |
Mon, 29 October 2012 04:47   |
Robert Gruendler Messages: 66 Registered: June 2011 |
Member |
Hi Luis,
i'm 100% sure that the regular updatesite works, no need to manually add anything to eclipse.
Simply download "Eclipse Classic 4.2.1" "http://www.eclipse.org/downloads/
Then open up eclipse, go to "Help -> Install New Software", select the "Juno - http://download.eclipse.org/releases/juno" entry from the "Work with" dropdown.
Under the "Web, XML, Java EE and OSGi Enterprise Developmet" category, select "PHP Development Tools (PDT) SDK Feature 3.1.1.201209101312".
This will install PDT, and everything should work out of the box. I'm so sure about that because i've started with a PDT tutorial this weekend, where i tested
the whole install process multiple times: http://blog.dubture.com/2012/10/improving-your-productivity-with.html
If you still have troubles, you can get live-help by joining the #pdt irc channel on freenode, i'm around most of the time (pulse00).
| Re: Cannot install PDT as plugin in Eclipse Classic 4.2 [message #995564 is a reply to message #962683] |
Sun, 30 December 2012 08:35  |
Junior Member |
Hello again. Sorry for the delay. I was using PHPDesigner meanwhile, but I'm going to give it a try again.
Robert: I did what you said in your last message, and everything went smooth. Thanks for you help!
So you mean that doing so (fetching from the Juno repo instead of the PDT repo) will completely install PDT? I don't need to load anything from the PDT repo afterwards?
FUDForum. Page generated in 0.02488 seconds
