| Is SVN Authentication working in buckmisnter? [message #909069] |
Thu, 06 September 2012 09:39  |
Hi guys,
I am trying to configure the buckminster svn client to access to a encripted repository. I do introduce the url as http://user:pwd@repository but i receive the following errors in the headless version:
Subclipse:
ERROR [0001] : No suitable provider for component xx.xx.xx.xx.feature:eclipse.feature was found in resourceMap file:/home/kasas/Workspaces/BuckminsterWorkspace/xxx.xxx.xxx.xxx/x.rmap
ERROR [0001] : No suitable provider for component esa.ssa.dpc.hmi.feature:eclipse.feature was found in searchPath esa.ssa.dpc.hmi
ERROR [0001] : Rejecting provider svn(https://user:pwd@repository{0}[https://user:pwd@repo/plugin]): No component match was found
ERROR org.tigris.subversion.svnclientadapter.SVNClientException: org.apache.subversion.javahl.ClientException: svn: E175002: unknown host
svn: E175002: PROPFIND request failed on 'XXXXXXX'
ERROR [0001] : No suitable provider for component esa.ssa.dpc.hmi.feature:eclipse.feature was found in searchPath org.eclipse.nebula
ERROR [0001] : Rejecting provider p2(http://download.eclipse.org/technology/nebula/snapshot[http://download.eclipse.org/technology/nebula/snapshot]): No component match was found
ERROR [0001] : No suitable provider for component esa.ssa.dpc.hmi.feature:eclipse.feature was found in searchPath org.eclipse.platform
ERROR [0001] : Rejecting provider p2(http://download.eclipse.org/eclipse/updates/3.7[http://download.eclipse.org/eclipse/updates/3.7]): No component match was found
ERROR [0001] : No suitable provider for component esa.ssa.dpc.hmi.feature:eclipse.feature was found in searchPath org.eclipse.indigo
ERROR [0001] : Rejecting provider p2(http://download.eclipse.org/releases/indigo[http://download.eclipse.org/releases/indigo]): No component match was found
INFO: TAG-ID 0001 = Query for esa.ssa.dpc.hmi.feature:eclipse.feature
Subversive:
ERROR [0001] : Rejecting provider svn(https://user:pwd@repo{0}[https://user:pwd@repo/xx.xx.xx.xx.feature]): No component match was found
ERROR org.eclipse.team.svn.core.connector.SVNConnectorAuthenticationException: svn: E170001: Authentication required for '<https://xxx:446> Subversion repository'
Integrating them into the Eclipse IDE I can access to the repository via subclipse if I introduce my user and password everything goes fine. The problem is I want to automate the building with hudson and I dont find the solution.
Thanxs in advance
[Updated on: Thu, 06 September 2012 09:45] Report message to a moderator
| Re: Is SVN Authentication working in buckmisnter? [message #924999 is a reply to message #909069] |
Thu, 27 September 2012 05:51  |
Matthew Webber Messages: 180 Registered: December 2010 |
Try checking out something from the subversion repository at the command line, using the same url etc as Buckminster would use, and see if it works there. Do this as the same userid that is failing (eg, the hudson userid), which might be different from the username that you are trying to authenticate to subversion as.
I have see Buckminster headless materialize fail if, e.g. there is a prompt for a certificate to be accepted.
Also, what version of Buckminster are you using?
Matthew
FUDForum. Page generated in 0.01861 seconds
