Home » Modeling » TMF (Xtext) » Split grammar (multiple grammars) in 1 project?
Split grammar (multiple grammars) in 1 project? [message #922732] Tue, 25 September 2012 05:21 Go to next message
Vil Lpz is currently offline Vil Lpz
Hello.
I'm try to split the "xtext project example" grammar in two files, but i think I do something wrong...
The files look like this:
MyDsl.xtext:
grammar org.xtext.example.mydsl.MyDsl with org.xtext.example.mydsl.Other
generate myDsl "http-://www.xtext.org/example/mydsl/MyDsl"
Model:
	greetings+=Greeting*
Other.xtext:
grammar org.xtext.example.mydsl.Other with org.eclipse.xtext.common.Terminals
generate other "http-://www.xtext.org/example/mydsl/Other"
Greeting:
	'Hello' name=ID '!';
My mwe2 look's like this:
module org.xtext.example.mydsl.GenerateMyDsl
import org.eclipse.emf.mwe.utils.*
import org.eclipse.xtext.generator.*
import org.eclipse.xtext.ui.generator.*
var grammarURI = "classpath:/org/xtext/example/mydsl/MyDsl.xtext"
var file.extensions = "split"
var projectName = "splitTest"
var runtimeProject = "../${projectName}"
Workflow {
    bean = StandaloneSetup {
            scanClassPath = true
            platformUri = "${runtimeProject}/.."
            // The following two lines can be removed, if Xbase is not used.
            registerGeneratedEPackage = "org.eclipse.xtext.xbase.XbasePackage"
            registerGenModelFile = "platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel"
       // registerGeneratedEPackage = "mymw.ideal2dsl.Types"
        registerGenModelFile = "platform:/resource/${projectName}/src-gen/org/xtext/example/mydsl/Other.genmodel"
        component = DirectoryCleaner {
            directory = "${runtimeProject}/src-gen"
            directory = "${runtimeProject}.ui/src-gen"
        component = Generator {
            pathRtProject = runtimeProject
            pathUiProject = "${runtimeProject}.ui"
            pathTestProject = "${runtimeProject}.tests"
            projectNameRt = projectName
            projectNameUi = "${projectName}.ui"
            language = {
                uri = "classpath:/org/xtext/example/mydsl/Other.xtext"
                fileExtensions = "__none"
                // Java API to access grammar elements (required by several other fragments)
                fragment = grammarAccess.GrammarAccessFragment {}
                // generates Java API for the generated EPackages
                fragment = ecore.EcoreGeneratorFragment {
                // referencedGenModels = "
                //  platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel,
                //  platform:/resource/org.eclipse.xtext.common.types/model/JavaVMTypes.genmodel
                // Serializer 2.0
                fragment = serializer.SerializerFragment {
                	generateStub = false
                // the serialization component (1.0)
                // fragment = parseTreeConstructor.ParseTreeConstructorFragment {}
                // a custom ResourceFactory for use with EMF
                fragment = resourceFactory.ResourceFactoryFragment {
                    fileExtensions = file.extensions
                // The antlr parser generator fragment.
                fragment = parser.antlr.XtextAntlrGeneratorFragment {
                //  options = {
                //      backtrack = true
                // java-based API for validation
                fragment = validation.JavaValidatorFragment {
                //    composedCheck = "org.eclipse.xtext.validation.ImportUriValidator"
                //    composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
                // scoping and exporting API
                // fragment = scoping.ImportURIScopingFragment {}
                // fragment = exporting.SimpleNamesFragment {}
                fragment = scoping.ImportNamespacesScopingFragment {}
                fragment = exporting.QualifiedNamesFragment {}
                fragment = builder.BuilderIntegrationFragment {}
                // generator API
                fragment = generator.GeneratorFragment {
                    generateMwe = false
                    generateJavaMain = false
                // formatter API
                fragment = formatting.FormatterFragment {}
                // labeling API
                fragment = labeling.LabelProviderFragment {}
                // outline API
                fragment = outline.OutlineTreeProviderFragment {}
                fragment = outline.QuickOutlineFragment {}
                // quickfix API
                fragment = quickfix.QuickfixProviderFragment {}
                // content assist API
                fragment = contentAssist.JavaBasedContentAssistFragment {}
                // generates a more lightweight Antlr parser and lexer tailored for content assist
                fragment = parser.antlr.XtextAntlrUiGeneratorFragment {}
                // generates junit test support classes into Generator#pathTestProject
                fragment = junit.Junit4Fragment {}
                // project wizard (optional)
                // fragment = projectWizard.SimpleProjectWizardFragment {
                //      generatorProjectName = "${projectName}"
                //      modelFileExtension = file.extensions
                // rename refactoring
                fragment = refactoring.RefactorElementNameFragment {}
                // provides the necessary bindings for java types integration
                fragment = types.TypesGeneratorFragment {}
                // generates the required bindings only if the grammar inherits from Xbase
                fragment = xbase.XbaseGeneratorFragment {}
                // provides a preference page for template proposals
                fragment = templates.CodetemplatesGeneratorFragment {}
                // provides a compare view
                fragment = compare.CompareFragment {
            language = {
                uri = grammarURI
                // Serializer 2.0
                //  options = {
                //      backtrack = true
                // generator API
                    generateMwe = false
                // formatter API
                // labeling API
                // outline API
                // quickfix API
But I think I have something incorrect, because when I run the ui project I obtain this error:
!ENTRY org.eclipse.osgi 4 0 2012-09-25 11:57:57.616
!MESSAGE An error occurred while automatically activating bundle splitTest.ui (407).
!STACK 0
org.osgi.framework.BundleException: The activator org.xtext.example.mydsl.ui.internal.MyDslActivator for bundle splitTest.ui is invalid
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:172)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:679)
	at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:300)
	at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
	at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:263)
	at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:469)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
	at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:395)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:464)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
	at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:340)
	at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1212)
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
	at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
	at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
	at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
	at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugin.java:273)
	at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:269)
	at org.eclipse.ui.internal.registry.EditorDescriptor.createEditor(EditorDescriptor.java:235)
	at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:283)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPart(CompatibilityPart.java:249)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPart(CompatibilityEditor.java:60)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:286)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:857)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:837)
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:111)
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:318)
	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:240)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:161)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
	at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:141)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:889)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:623)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:725)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:696)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:690)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:675)
	at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1042)
	at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:98)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:639)
	at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:59)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:635)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$6.run(PartRenderingEngine.java:511)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:496)
	at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:74)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:59)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:103)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:77)
	at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:626)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:961)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:585)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: java.lang.ClassNotFoundException: org.xtext.example.mydsl.ui.internal.MyDslActivator
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:165)
	... 147 more
Root exception:
!ENTRY org.eclipse.ui 4 4 2012-09-25 11:57:57.632
!MESSAGE Unable to create part
!ENTRY org.eclipse.ui 4 1 2012-09-25 11:57:57.632
!MESSAGE Plug-in splitTest.ui was unable to load class org.xtext.example.mydsl.ui.MyDslExecutableExtensionFactory.
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in splitTest.ui was unable to load class org.xtext.example.mydsl.ui.MyDslExecutableExtensionFactory.
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:176)
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle splitTest.ui (407).
	at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:122)
	... 129 more
Caused by: org.osgi.framework.BundleException: The activator org.xtext.example.mydsl.ui.internal.MyDslActivator for bundle splitTest.ui is invalid
	... 141 more
	... 147 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2012-09-25 11:57:57.637
!STACK 0
[Updated on: Tue, 25 September 2012 05:59]
Report message to a moderator
Re: Split grammar (multiple grammars) in 1 project? [message #924810 is a reply to message #922732] Thu, 27 September 2012 02:24 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian Dietrich
cannot reproduce this. there must be another problem with your project.
did you try this with a clean project?
~Christian
Re: Split grammar (multiple grammars) in 1 project? [message #924845 is a reply to message #924810] Thu, 27 September 2012 03:09 Go to previous message
Hello Christian.
You are right there was a problem with my project. I create a new project with different name and all works ok.
The mwe2 it´s ok? Or are there lines left over?
I have other related problem if you can help me please...
http://www.eclipse.org/forums/index.php/m/923907/#msg_923907
Thanks a lot!
Greetings.
Previous Topic:Exclude keywords in certain context
Next Topic:Where is spell checking configured?
Current Time: Sat May 25 23:22:53 EDT 2013
Powered by FUDForum. Page generated in 0.03660 seconds
