Home » Eclipse Projects » DSDP - Real-Time Software Components (RTSC) » Listing named values of an enum from .xs script.
Listing named values of an enum from .xs script. [message #923437] Tue, 25 September 2012 19:00 Go to next message
James Lockwood is currently offline James Lockwood
How can I list all of the named values of a particular enum from a script?
For example If I had the following decalred in a module IMuxOptions:
	metaonly enum Gpio0MuxSettings {
		GPIO0_MUXVALUE_GPIO = 0,			/*! GPIO (0) */
		GPIO0_MUXVALUE_U0Rx = 1,			/*! U0Rx (1) */
		GPIO0_MUXVALUE_I2C1SCL = 8,			/*! I2C1SCL (8) */
		GPIO0_MUXVALUE_U1Rx = 9				/*! U1Rx (9) */
I want to first get the number of items in Gpio0MuxSettings, then cycle through each and extract the strings. So given an object, where I find <obj>.$category == "EnumVal", I want to determine which enum value it is bound to (in this case "Gpio0MuxSettings"), the number of possible named enumeration settings, and what these names are. The output would ideally be something like this:
The object is: gpio0.mux,
gpio0.mux is an enum of type "IMuxOptions.Gpio0MuxSettings",
There are 4 named values. They are:
GPIO0_MUXVALUE_GPIO
GPIO0_MUXVALUE_U0Rx
GPIO0_MUXVALUE_U1Rx
Thanks in advance. It would seem straightforward, but it is eluding me.
James Lockwood
Re: Listing named values of an enum from .xs script. - Solved [message #923830 is a reply to message #923437] Wed, 26 September 2012 04:28 Go to previous messageGo to next message
Just got something that works and thought I'd share.
var names;
var myenum = IMuxOptions.$spec.getDecl("Gpio7MuxSettings");
var myvals = myenum.getVals();
for (i=0; i < myvals.size(); i++) {
	print("array at index" + i + " = " + myvals.get(i).getName() );
In general, I find the documentation and examples for RTSC very good. However, the stuff about the Java functions and how to use $spec is lacking. There was a lot of trial and error to get this working.
Re: Listing named values of an enum from .xs script. - Solved [message #924556 is a reply to message #923830] Wed, 26 September 2012 20:11 Go to previous message
Sasha Slijepcevic is currently offline Sasha Slijepcevic
Member
James,
just wanted to confirm that the solution you found is pretty much the only one that would work. There is a Java object that keeps track of all values for an enumeration type, but there is no public function or field to look up its content.
Even the code that generates C constants out of an enumeration (when needed) uses $spec to find all defined enumeration constants.
Previous Topic:console input during debugging
Next Topic:file name too long error (windows)
Current Time: Wed May 29 03:12:35 EDT 2013
Powered by FUDForum. Page generated in 0.08894 seconds
