Home » Newcomers » Newcomers » No icon in Ubuntu Launcher for Eclipse(Missing Launcher Icon in Ubuntu)
No icon in Ubuntu Launcher for Eclipse [message #924380] Wed, 26 September 2012 16:02 Go to next message
David Patterson is currently offline David Patterson
I'm running Eclipse on Ubuntu. (I've had the same result with both Juno and Indigo.)
The code is running fine from a directory in my home directory. The Eclipse icon shows up for a desktop icon, but the launcher (vertical column of icons on the left side of the screen) shows a generic blank entry, not the Eclipse icon.
I also had a version running from the usr/bin directory, and its icon did show up correctly.
Is there a way to point to the correct icon so it shows up in the launcher?
Dave P
Re: No icon in Ubuntu Launcher for Eclipse [message #1003497 is a reply to message #924380] Mon, 21 January 2013 06:20 Go to previous message
Flavelle Ballem is currently offline Flavelle Ballem
Member
Don't know if you have figured it out yet.
If you have not, then you may want to try installing eclipse using the instructions here: https://wiki.ubuntu.com/fballem/Software%2012.04#Eclipse
Before you start this, you should install users and groups application (use Software Center) so that you can easily manage groups. These instructions have worked reliably for me for several versions of ubuntu, including 12.04.
Previous Topic:Webdav and Ftp
Next Topic:Using external jar file from eclipse plugin
Current Time: Tue May 21 09:56:48 EDT 2013
Powered by FUDForum. Page generated in 0.01589 seconds
