Home » Eclipse Projects » Eclipse Platform » Automatically add a project nature
Automatically add a project nature [message #924182] Wed, 26 September 2012 11:34 Go to next message
drew frantz is currently offline drew frantz
What is the standard way to automatically add a project nature to a project,
one way would be to use an IResourceChangeListener and then check the
contents of an open project to see if the particular custom nature should be
added. If that is the correct way, where would I implement a global resource
IResourceChangeListener to carry out the modification.
Re: Automatically add a project nature [message #938116 is a reply to message #924182] Tue, 09 October 2012 10:58 Go to previous message
Dani Megert is currently offline Dani Megert
> project, one way would be to use an IResourceChangeListener and then
> check the contents of an open project to see if the particular custom
> nature should be added. If that is the correct way, where would I
> implement a global resource IResourceChangeListener to carry out the
> modification.
Do you want to add the nature when creating a new project?
Dani
Previous Topic:Problem with key bindings
Next Topic:How to stop annoying repeated prompts from Ant config folder_prompt variable?
Current Time: Tue May 21 04:37:03 EDT 2013
Powered by FUDForum. Page generated in 0.01947 seconds
