Home » Eclipse Projects » EclipseLink » select records where elementcollection contains one of parameter list(jpql select elementcollection contain parameter list)
select records where elementcollection contains one of parameter list [message #923864] Wed, 26 September 2012 05:01 Go to next message
Rolf Gisler is currently offline Rolf Gisler
A user may play many roles. I want to fetch all users which have at least one role out of a parameter list.
The data definition looks as follows:
@Entity
public class User implements Serializable {
    @Id
    @Column(name = "Id",
            nullable = false)
    private long id;
    @Column(name = "LoginName",
            length = 30,
            unique = true,
            nullable = false)
    private String loginName;
    @ElementCollection
    @Enumerated(EnumType.STRING)
    @CollectionTable(name = "Role",
                     joinColumns = @JoinColumn(name = "Id"),
                     uniqueConstraints = @UniqueConstraint(columnNames = {"Id", "Role"}))
    @Column(name = "Role")
    private Set<RoleType> roles = new HashSet<RoleType>();
public enum RoleType {
    GUEST,
    ACCOUNTING,
    ADMIN,
    OPERATOR;
Now I want all users which have at least one role out of a parameter list. The list may be dynamically. I tried the following code:
String sql = "SELECT DISTINCT u FROM User u JOIN u.roles AS r WHERE r IN :filteredRoles";
Query query = entityManager.createQuery(sql);
List<RoleType> filteredRoles = new ArrayList<RoleType>();
filteredRoles.add(RoleType.ADMIN);
filteredRoles.add(RoleType.ACCOUNTING);
query.setParameter("filteredRoles", filteredRoles);
List<User> result = (List<User>) query.getResultList();
and receive the following exception:
Exception [EclipseLink-6078] (Eclipse Persistence Services - 2.3.2.v20111125-r10461): org.eclipse.persistence.exceptions.QueryException
Exception Description: The class of the argument for the object comparison is incorrect.
Expression: [null]
Mapping: [org.eclipse.persistence.mappings.DirectCollectionMapping[roles]]
Argument: [[ADMIN, ACCOUNTING]]
Query: ReadAllQuery(referenceClass=User sql="SELECT DISTINCT t0.Id FROM User t0, Role t1 WHERE ((t1.Role IN ?) AND (t1.Id = t0.Id))")
I tried several variations of the JPQL but didn't succeed.
Another question would be how this JQPL would look like with CriteriaBuilder?
Re: select records where elementcollection contains one of parameter list [message #930653 is a reply to message #923864] Tue, 02 October 2012 10:11 Go to previous message
James Sutherland is currently offline James Sutherland
I think this was fixed in 2.4, can you try the latest release?
James : Wiki : Book : Blog
Previous Topic:Eclipselink mongoDB native query find() not working
Next Topic:JTA
Current Time: Tue May 21 16:11:48 EDT 2013
Powered by FUDForum. Page generated in 0.01589 seconds
