Home » Eclipse Projects » Rich Client Platform (RCP) » [CDO] Multi master (clone)
[CDO] Multi master (clone) [message #908552] Wed, 05 September 2012 10:55 Go to next message
Ricky de Klerck is currently offline Ricky de Klerck
Is there an example available which shows how to user multi masters which synchronise with each other (like a clone)? On http://www.eclipse.org/cdo/documentation/ it says: "One way is to create a clone of a complete remote repository, including all history of all branches. Such a clone is continuously synchronized with its remote master.."
But I can't find any documentation on it..
Re: [CDO] Multi master (clone) [message #915398 is a reply to message #908552] Mon, 17 September 2012 03:51 Go to previous messageGo to next message
Nobody?
Re: [CDO] Multi master (clone) [message #922640 is a reply to message #915398] Tue, 25 September 2012 03:39 Go to previous messageGo to next message
I managed to create a master and clone following the examples in org.eclipse.emf.cdo.examples.
I still have one problem now.. I've set up 2 clients, one connected to the master and one to the clone. When I save an object in the clone, everything is synchronized well, but the other way around (save object in master) doesn't work. The changes aren't pushed (or pulled) from master to clone. Anybody had this problem before?
Re: [CDO] Multi master (clone) [message #923794 is a reply to message #922640] Wed, 26 September 2012 03:45 Go to previous messageGo to next message
Eike Stepper is currently offline Eike Stepper
I only found this accidentally. Please ask CDO question in the EMF newsgroup.
Cheers
/Eike
Re: [CDO] Multi master (clone) [message #923800 is a reply to message #923794] Wed, 26 September 2012 03:54 Go to previous message
Ok, thank you. I will do that.
Previous Topic:Process for adding custom language validation for Eclipse 3.x RCP?
Next Topic: how can I make this editor using RCP?
Current Time: Sun May 19 03:04:38 EDT 2013
Powered by FUDForum. Page generated in 0.02242 seconds
