Home » Modeling » ATL » Package with URI was not found in ATL plugin
Package with URI was not found in ATL plugin [message #923162] Tue, 25 September 2012 12:54 Go to next message
Fernanda R.F. is currently offline Fernanda R.F.
Member
I'm trying to convert a magic draw uml model with ATL plugin using as metamodel another uml file generated by magic draw, however I'm getting the following error:
org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http://www.eclipse.org/uml2/2.0.0/UML' not found.
The same metamodel works when I'm running it in ATL, however when I'm trying to use ATL plugin I'm getting this error. I already imported uml2/2.0.0 jar file, but the error is still appearing.
What could be wrong?
Re: Package with URI was not found in ATL plugin [message #923252 is a reply to message #923162] Tue, 25 September 2012 15:03 Go to previous messageGo to next message
lili Missing name is currently offline lili Missing name
I think you have to register the package ...someting like this
EPackage.Registry.INSTANCE.put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);                EPackage.Registry.INSTANCE.put("'http://www.eclipse.org/uml2/2.0.0/UML",UMLPackage.eINSTANCE);
Re: Package with URI was not found in ATL plugin [message #923743 is a reply to message #923162] Wed, 26 September 2012 02:44 Go to previous messageGo to next message
If you're using Juno then this is could well be
https://bugs.eclipse.org/bugs/show_bug.cgi?id=389542.
Ed Willink
On 25/09/2012 17:54, Fernanda R.F. wrote:
Re: Package with URI was not found in ATL plugin [message #925340 is a reply to message #923743] Thu, 27 September 2012 12:21 Go to previous messageGo to next message
Member
Thanks for answers.
I 'll see what I could do about this problem.
Re: Package with URI was not found in ATL plugin [message #926281 is a reply to message #925340] Fri, 28 September 2012 09:39 Go to previous messageGo to next message
Member
I put the code as lili Mising name suggested, however I'm getting this error now:
org/eclipse/uml2/common/util/CacheAdapter
Some suggestion?
Re: Package with URI was not found in ATL plugin [message #926439 is a reply to message #926281] Fri, 28 September 2012 12:57 Go to previous messageGo to next message
Member
Updating...
I inserted a new library (org.eclipse.uml2.common.util.*;) and now I'm getting a different problem:
org.eclipse.m2m.atl.core.ATLCoreException: Error loading metamodelos/UML_Standard_Profile.UML_Standard_Profile.profile.uml: org.eclipse.emf.ecore.xmi.IllegalValueException: Value 'UML Standard Profile' is not legal.
This value is as "name = UML Standard Profile" in UML file.
What could I do to solve it?
Re: Package with URI was not found in ATL plugin [message #929436 is a reply to message #926439] Mon, 01 October 2012 09:05 Go to previous messageGo to next message
Member
I created again the plugin and registered the UML path : http://www.eclipse.org/uml2/2.0.0/UML
And now I'm getting this error:
Exception in thread "main" java.lang.NoClassDefFoundError: org/eclipse/uml2/types/TypesPackage
	at org.eclipse.uml2.uml.internal.impl.UMLPackageImpl.init(UMLPackageImpl.java:1900)
	at org.eclipse.uml2.uml.UMLPackage.<clinit>(UMLPackage.java:82)
I'm using 2 metamodels, where one is an ecore file and other is an UML file (generated by Magic Draw - UML Standard Profile.uml
What could I do?
Re: Package with URI was not found in ATL plugin [message #929523 is a reply to message #929436] Mon, 01 October 2012 10:35 Go to previous messageGo to next message
a) Wait for a fix to https://bugs.eclipse.org/bugs/show_bug.cgi?id=389542
b) Open all relevant UML files, mosted nested first, with the UML Model
Editor do a dummy edit and save so that the format is converted
c) revert to MDT/UML2 3.x
Ed Willink
On 01/10/2012 15:05, Fernanda R.F. wrote:
> at
> What could I do?
Re: Package with URI was not found in ATL plugin [message #929564 is a reply to message #929523] Mon, 01 October 2012 11:12 Go to previous messageGo to next message
Member
Thanks Ed Willink.
The problem is that I need to delivery it in the end of this month, it's my graduation work. I'll wait for the fix and try to created models with UML 3 so.
Re: Package with URI was not found in ATL plugin [message #930698 is a reply to message #929564] Tue, 02 October 2012 10:51 Go to previous messageGo to next message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=389542#c19 should be a fix
for you.
It would be helpful to know that it is.
Ed Willink
On 01/10/2012 17:12, Fernanda R.F. wrote:
> Thanks Ed Willink.
Re: Package with URI was not found in ATL plugin [message #930908 is a reply to message #930698] Tue, 02 October 2012 14:56 Go to previous messageGo to next message
Member
Hi Ed,
I tried the code in that link, and I updated my eclipse juno, however I'm getting an error.
A put it in the code
EcoreResourceFactoryImpl resourceSet = null;
resourceSet.createResource(URI.createFileURI("metamodels/UML.uml"));
And I'm getting this now:
Exception in thread "main" java.lang.NullPointerException
	at org.eclipse.m2m.atl.uml.files.myClass.<init>(myClass.java:103)
	at org.eclipse.m2m.atl.uml.files.myClass.main(myClass.java:79)
Have you a suggestion about what I can do?
Re: Package with URI was not found in ATL plugin [message #931343 is a reply to message #930908] Wed, 03 October 2012 01:28 Go to previous messageGo to next message
The change seems to have successfully fixed reading the nested profiles,
so we move on
In https://bugs.eclipse.org/bugs/show_bug.cgi?id=389542 later comments
identify a problem
creating *.uml, that will in due course work when you do
resourceSet.createResource(URI.createFileURI("metamodels/UML.uml"),
ContentHandler.UNSPECIFIED_CONTENT_TYPE);
Today you will need to use an explicit content type; perhaps
UMLResource.UML_4_0_0_CONTENT_TYPE_IDENTIFIER);
Ed Willink
On 02/10/2012 20:56, Fernanda R.F. wrote:
> Hi Ed,
Re: Package with URI was not found in ATL plugin [message #931758 is a reply to message #931343] Wed, 03 October 2012 09:45 Go to previous messageGo to next message
Member
Hi Ed,
Thanks for your answer!
I'm trying to use the following code as suggested:
However, eclipse is asking me to remove this second part (UMLResource.UML_4....) because it is not compatible with "createResource" method, that uses just URI like : createResource (URI uri);
I don't know what to do to solve it.
Re: Package with URI was not found in ATL plugin [message #931860 is a reply to message #931758] Wed, 03 October 2012 11:36 Go to previous messageGo to next message
The
Resource createResource(URI uri, String contentType)
is part of the ResourceSet API.
is a String, so you must have a stupid Java typo.
Ed Willink
On 03/10/2012 15:45, Fernanda R.F. wrote:
> Hi Ed,
> uri);
Re: Package with URI was not found in ATL plugin [message #931889 is a reply to message #931860] Wed, 03 October 2012 12:14 Go to previous messageGo to next message
Member
Thanks for your answer Ed, I'll find the error in my code.
[Updated on: Wed, 03 October 2012 12:22]
Report message to a moderator
Re: Package with URI was not found in ATL plugin [message #931905 is a reply to message #931889] Wed, 03 October 2012 12:33 Go to previous messageGo to next message
Member
I found the problem, and now I'm getting a new (or not so new) problem.
When I try to run the project is returning it:
at org.eclipse.m2m.atl.uml.files.Uml2metamodel.main(Uml2metamodel.java:85)
Suggestions?
Re: Package with URI was not found in ATL plugin [message #932026 is a reply to message #931905] Wed, 03 October 2012 15:08 Go to previous messageGo to next message
I'm not an ATL developer or user; this now looks like an ATL issue;
quite possibly the same createResource issue.
Ed Willink
> at
> Suggestions?
Re: Package with URI was not found in ATL plugin [message #936373 is a reply to message #932026] Sun, 07 October 2012 20:35 Go to previous messageGo to next message
Member
I was testing it, and when I remove the code :
I stop getting the error: Exception in thread "main" java.lang.NullPointerException
and then I'm starting getting this error:
org.eclipse.m2m.atl.core.ATLCoreException: Error loading models/vvv.uml: org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'Model' is not found or is abstract. (file:///C:/test/org.eclipse.m2m.atl.uml2metamodel/models/vvv.uml, 3, 75)
	at org.eclipse.m2m.atl.core.emf.EMFInjector.inject(EMFInjector.java:70)
	at org.eclipse.m2m.atl.core.emf.EMFInjector.inject(EMFInjector.java:84)
	at org.eclipse.m2m.atl.uml.files.Uml2metamodel.loadModels(Uml2metamodel.java:146)
	at org.eclipse.m2m.atl.uml.files.Uml2metamodel.main(Uml2metamodel.java:92)
Caused by: org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'Model' is not found or is abstract. (file:///C:/test/org.eclipse.m2m.atl.uml2metamodel/models/vvv.uml, 3, 75)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406)
	at org.eclipse.m2m.atl.core.emf.EMFInjector.inject(EMFInjector.java:65)
	... 3 more
What could I do? I'm not expert in ATL lot less in Java... Sad
Re: Package with URI was not found in ATL plugin [message #936572 is a reply to message #936373] Mon, 08 October 2012 01:44 Go to previous messageGo to next message
Removing the line goes backwards so that you get a more fundamental error.
Depending exactly when you last synchronized with GIT will affect what
works.
The most recent change in MDT/UML2's GIT IMHO was a bad one.
Can you clarify exactly what MDT/UML2 release/branch/commit you are using?
Ed Willink
On 08/10/2012 01:35, Fernanda R.F. wrote:
> at
> at
> at
> at
> Caused by:
> at
> at
> at
> at
> ... 3 more
> What could I do? I'm not expert in ATL lot less in Java... :(
Re: Package with URI was not found in ATL plugin [message #937893 is a reply to message #936572] Tue, 09 October 2012 06:58 Go to previous messageGo to next message
Member
Sorry Ed, but how I see it? I'm not a developer... Sad
Re: Package with URI was not found in ATL plugin [message #937902 is a reply to message #937893] Tue, 09 October 2012 07:08 Go to previous messageGo to next message
Thanks for trying to help. Best to wait till we think we have a good fix
available.
Ed Willink
On 09/10/2012 11:58, Fernanda R.F. wrote:
> Sorry Ed, but how I see it? I'm not a developer... :(
Re: Package with URI was not found in ATL plugin [message #938051 is a reply to message #937902] Tue, 09 October 2012 10:00 Go to previous messageGo to next message
Member
Right... thanks for your answer and help Ed.
I'll wait.
Re: Package with URI was not found in ATL plugin [message #956246 is a reply to message #938051] Wed, 24 October 2012 06:55 Go to previous messageGo to next message
Member
I'd know if there is a fix to that bug, or if there is a possible data to solve it?
I really need this fix to finish my work.
Re: Package with URI was not found in ATL plugin [message #1023123 is a reply to message #923162] Sat, 23 March 2013 06:08 Go to previous message
Mathias Colpaert is currently offline Mathias Colpaert
I have posted a similar question in a new topic here.
Previous Topic:Elements of xmi files to the graphics
Next Topic:multiple output models conform to the same metamodel?
Current Time: Wed May 22 12:04:15 EDT 2013
Powered by FUDForum. Page generated in 0.90733 seconds
