| HashPartitioningPolicy fails for large IDs of type long [message #916123] |
Tue, 18 September 2012 11:19  |
Alexander Bätz Messages: 5 Registered: August 2012 |
Junior Member |
I'm toying with eclipse link partitioning for my current project. we have an id generator that is base on the twitter id schema (first x bits = timestamp (seconds), 10 bits machine id, rest counter per second)
this means our ids are pretty large by default. the hashpartitioningpolicy uses the following line to find the target server:
int index = value.hashCode() % this.connectionPools.size();
in java % is the remainder function that can be negative IF value.hashCode() returns a negative value (its not a real modulo). since our Long ids are large the resulting hash code can indeed become negative, which causes a negative index, which causes an ArrayIndexOutOfBoundsException.
I'm going to work around this by implementing my own custom policy but this really should be fixed.
Greetings,
Alexander
FUDForum. Page generated in 0.02420 seconds
