Home » Modeling » TMF (Xtext) » Extend xtend with more extension methods
| Extend xtend with more extension methods [message #922052] |
Mon, 24 September 2012 13:34  |
Hallvard Traetteberg Messages: 539 Registered: July 2009 Location: Trondheim, Norway |
I'm generating code with xtend2 and wonder if I could make the code
nicer by defining some extra operator_doubleArrow method, so the =>
operator can be used with an ITreeAppendable on the left hand side.
E.g. instead of append("something") newLine // it is an ITreeAppendable
I could write it => "something" => '\n'
Is it possible to add such extra methods without rebuilding xtend2? E.g.
by defining an extension class in your xtext project and using some
extension point, thus extending xtend?
Hallvard
| Re: Extend xtend with more extension methods [message #922235 is a reply to message #922052] |
Mon, 24 September 2012 17:23   |
Sebastian Zarnekow Messages: 2788 Registered: July 2009 |
You can define a class with a method
operator_doubleArrow(ITreeAppendable, CharSequence) and use that one as
an extension, e.g.
extension MyTreeAppendableUtil
That should do the trick. No recompilation, no altering of the language,
just a library / an API in your project
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 24.09.12 19:34, schrieb Hallvard Trætteberg:
> Hallvard
| Re: Extend xtend with more extension methods [message #925330 is a reply to message #923018] |
Thu, 27 September 2012 12:10   |
On 25.09.12 07.42, Aaron Digulla wrote:
> I suggest to use the left-shift operator, though:
> out << "something" << '\n'
> is used my most other languages and shows the intent better (if you
> forget for a moment that it also means "shift") since it "points" the
> data into the right direction.
Yes, I came to the same conclusion after looking at the available
operators. I now use the following extension class. Note how the injects
allow serialization of expressions and types.
BTW, I also tried to use operators (extension methods) for higher order
functions like filter, map and reduce, but it seemed the type inference
had problems with the Procedure sublasses and their extensive use of
type parameters.
Hallvard
----8<-----------------------------
package org.ptolemy.xtext.generator;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.xtext.common.types.JvmTypeReference;
import org.eclipse.xtext.xbase.XExpression;
import org.eclipse.xtext.xbase.compiler.TypeReferenceSerializer;
import org.eclipse.xtext.xbase.compiler.XbaseCompiler;
import org.eclipse.xtext.xbase.compiler.output.ITreeAppendable;
import org.eclipse.xtext.xbase.lib.Inline;
import org.eclipse.xtext.xbase.lib.IterableExtensions;
import org.eclipse.xtext.xbase.lib.Pair;
import org.eclipse.xtext.xbase.lib.Functions.Function1;
import org.eclipse.xtext.xbase.lib.Functions.Function2;
import org.eclipse.xtext.xbase.lib.Procedures.Procedure1;
import org.eclipse.xtext.xbase.lib.internal.BooleanFunctionDelegate;
import org.eclipse.xtext.xbase.lib.internal.FunctionDelegate;
import com.google.common.collect.Iterables;
import com.google.inject.Inject;
public class TreeAppendableUtil {
@Inject private XbaseCompiler xbaseCompiler;
@Inject private TypeReferenceSerializer typeReferenceSerializer;
public ITreeAppendable operator_doubleLessThan(ITreeAppendable
appendable, CharSequence content) {
if (content.length() > 0) {
preAppend(appendable, content.charAt(0));
appendable.append(content);
postAppend(appendable, content.charAt(content.length() - 1));
return appendable;
public Pair<ITreeAppendable,? extends EObject>
operator_doubleLessThan(Pair<ITreeAppendable,? extends EObject>
operator_doubleLessThan(appendable.getKey(), content);
return appendable;
public ITreeAppendable preAppend(ITreeAppendable appendable, char c) {
switch (c) {
case '}': {
appendable.decreaseIndentation(); appendable.newLine(); break;
return appendable;
public ITreeAppendable postAppend(ITreeAppendable appendable, char c) {
switch (c) {
case '\n': {
case '{': {
appendable.increaseIndentation(); appendable.newLine(); break;
case ';': {
case '}': {
return appendable;
preAppend(appendable, c);
appendable.append(String.valueOf(c));
postAppend(appendable, c);
return appendable;
operator_doubleLessThan(appendable.getKey(), c);
return appendable;
appendable, XExpression expression) {
xbaseCompiler.toJavaExpression(expression, appendable);
return appendable;
operator_doubleLessThan(appendable.getKey(), expression);
return appendable;
appendable, JvmTypeReference type) {
typeReferenceSerializer.serialize(type, appendable.getValue(),
appendable.getKey());
return appendable;
| Re: Extend xtend with more extension methods [message #927674 is a reply to message #925330] |
Sat, 29 September 2012 19:19  |
Hi Hallvard,
please file tickets with your findings about Procedures, their type
arguments and the type inferrence.
Sebastian
Am 27.09.12 09:12, schrieb Hallvard Trætteberg:
> type parameters.
> Hallvard
> return appendable;
> return appendable;
> switch (c) {
> case '}': {
> break;
> return appendable;
> c) {
> switch (c) {
> case '\n': {
> case '{': {
> break;
> case ';': {
> case '}': {
> return appendable;
> return appendable;
> return appendable;
> return appendable;
> return appendable;
> return appendable;
Current Time: Sat May 25 03:08:19 EDT 2013
Powered by FUDForum. Page generated in 0.05538 seconds
