| make [message #921541] |
Mon, 24 September 2012 03:53 |
Michael Mising name Messages: 86 Registered: July 2009 |
Member |
after importing the makefile below I get:
make NewProject all
make: *** No rule to make target `NewProject'. Stop.
What could I be doing wrong?
Many thanks
# I release this sample under the MIT license: free for any use, provided
# you hold me harmless from any such use you make, and you retain my
# copyright on the actual sources.
# Copyright 2005 Jon Watte.
# AppShared Template
APPNAME := ../../game/NewProject
SOURCES := ../../../../Engine/source/main/main.cpp \
LDFLAGS := -g -m32
LDLIBS := -lstdc++
CFLAGS := -MMD -I. -Wfatal-errors -m32
CFLAGS += -DUNICODE
CFLAGS += -DTORQUE_SHARED
CFLAGS_DEBUG := $(CFLAGS) -ggdb
CFLAGS_DEBUG += -DTORQUE_DEBUG
CFLAGS_DEBUG += -DTORQUE_NET_STATS
CFLAGS_DEBUG += -DTORQUE_DEBUG_GUARD
CFLAGS += -O3
#CC := gcc
LD := gcc
APP_TARGETS += $(APPNAME)
APP_TARGETS_DEBUG += $(APPNAME)_DEBUG
OBJS_NewProject := $(patsubst ../../../../Engine/source/%,Release/NewProject/%.o,$(SOURCES))
OBJS_NewProject += $(patsubst ../../source/%, Release/NewProject/%.o,$(SOURCES))
OBJS_NewProject := $(filter %.o, $(OBJS_NewProject))
OBJS_NewProject_DEBUG := $(patsubst ../../../../Engine/source/%,Debug/NewProject/%.o,$(SOURCES))
OBJS_NewProject_DEBUG += $(patsubst ../../source/%, Debug/NewProject/%.o,$(SOURCES))
OBJS_NewProject_DEBUG := $(filter %.o, $(OBJS_NewProject_DEBUG))
# Deriving the actual prerequisite list name to use from the target
# name in the shell command is the "secret sauce" that makes this all
# work.
$(APPNAME): $(OBJS_NewProject) $(SHARED_LIB_TARGETS)
$(LD) $(LDFLAGS) -o $@ $(OBJS_NewProject) $(SHARED_LIB_TARGETS) $(LDLIBS)
$(APPNAME)_DEBUG: $(OBJS_NewProject_DEBUG) $(SHARED_LIB_TARGETS_DEBUG)
$(LD) $(LDFLAGS) -o $@ $(OBJS_NewProject_DEBUG) $(SHARED_LIB_TARGETS_DEBUG) $(LDLIBS)
Release/NewProject/%.asm.o: ../../../../Engine/source/%.asm
@mkdir -p $(dir $@)
nasm -f elf $< -o $@
Release/NewProject/%.o: ../../../../Engine/source/%
@mkdir -p $(dir $@)
$(CC) -c $(CFLAGS) $< -o $@
Debug/NewProject/%.asm.o: ../../../../Engine/source/%.asm
@mkdir -p $(dir $@)
Debug/NewProject/%.o: ../../../../Engine/source/%
@mkdir -p $(dir $@)
$(CC) -c $(CFLAGS_DEBUG) $< -o $@
release_NewProject: $(APPNAME)
debug_NewProject: $(APPNAME)_DEBUG
.PHONY: debug_NewProject release_NewProject
DEPS += $(patsubst %.o,%.d,$(OBJS_NewProject))
DEPS += $(patsubst %.o,%.d,$(OBJS_NewProject_DEBUG))
APPNAME :=
SOURCES :=
FUDForum. Page generated in 0.01972 seconds
