Home » Eclipse Projects » BPMN 2.0 Modeler » FIle access issue(Creating new BPMN diagram fails de to permission issues)
FIle access issue [message #920607] Sun, 23 September 2012 04:04 Go to next message
Grant Moss is currently offline Grant Moss
>>>>> Starting with a clean install of 3.7.2 plus the BPMN Editor from the site http://download.eclipse.org/bpmn2-modeler/site.
I start eclipse, create a new project then try to create a new BPMN model and get the following error:
org.eclipse.core.runtime.AssertionFailedException: assertion failed:
at org.eclipse.core.runtime.Assert.isTrue(Assert.java:110)
at org.eclipse.core.runtime.Assert.isTrue(Assert.java:96)
at org.eclipse.ui.part.MultiPageEditorPart.setActivePage(MultiPageEditorPart.java:1065)
at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:352)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:670)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1245)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1198)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1597)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:493)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:479)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:808)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:707)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:666)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2942)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2850)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2842)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2793)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2789)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2773)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2756)
at org.eclipse.bpmn2.presentation.Bpmn2ModelWizard.performFinish(Bpmn2ModelWizard.java:272)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:827)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:432)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3588)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3209)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.ui.internal.handlers.WizardHandler$New.executeHandler(WizardHandler.java:257)
at org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:277)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
>>>>> When I close eclipse and open again I get the following message:
org.eclipse.ui.PartInitException: The following resources could not be saved:
URI: file:/tmpMy._o8PcEQVUEeKr9Z8wCj-PCw, cause:
java.io.FileNotFoundException: /tmpMy._o8PcEQVUEeKr9Z8wCj-PCw (Permission denied)
at java.io.FileOutputStream.open(Native Method)
at java.io.FileOutputStream.<init>(FileOutputStream.java:209)
at java.io.FileOutputStream.<init>(FileOutputStream.java:160)
at org.eclipse.emf.ecore.resource.impl.FileURIHandlerImpl$1.<init>(FileURIHandlerImpl.java:71)
at org.eclipse.emf.ecore.resource.impl.FileURIHandlerImpl.createOutputStream(FileURIHandlerImpl.java:71)
at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterImpl.createOutputStream(ExtensibleURIConverterImpl.java:339)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:989)
at org.eclipse.bpmn2.modeler.ui.wizards.FileService$2$1.run(FileService.java:150)
at org.eclipse.emf.transaction.impl.TransactionalEditingDomainImpl.runExclusive(TransactionalEditingDomainImpl.java:328)
at org.eclipse.bpmn2.modeler.ui.wizards.FileService$2.run(FileService.java:161)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2326)
at org.eclipse.bpmn2.modeler.ui.wizards.FileService.saveInWorkspaceRunnable(FileService.java:169)
at org.eclipse.bpmn2.modeler.ui.wizards.FileService.save(FileService.java:107)
at org.eclipse.bpmn2.modeler.ui.wizards.FileService.createEmfFileForDiagram(FileService.java:102)
at org.eclipse.bpmn2.modeler.ui.wizards.BPMN2DiagramCreator.createDiagram(BPMN2DiagramCreator.java:58)
at org.eclipse.bpmn2.modeler.ui.editor.BPMN2Editor.createNewDiagramEditorInput(BPMN2Editor.java:404)
at org.eclipse.bpmn2.modeler.ui.editor.BPMN2Editor.init(BPMN2Editor.java:274)
at org.eclipse.ui.part.MultiPageEditorPart.addPage(MultiPageEditorPart.java:237)
at org.eclipse.bpmn2.modeler.ui.editor.BPMN2MultiPageEditor.addPage(BPMN2MultiPageEditor.java:312)
at org.eclipse.bpmn2.modeler.ui.editor.BPMN2MultiPageEditor.createDesignEditor(BPMN2MultiPageEditor.java:182)
at org.eclipse.bpmn2.modeler.ui.editor.BPMN2MultiPageEditor.createPages(BPMN2MultiPageEditor.java:161)
at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:348)
at org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(EditorAreaHelper.java:271)
at org.eclipse.ui.internal.EditorManager.setVisibleEditor(EditorManager.java:1459)
at org.eclipse.ui.internal.EditorManager$5.runWithException(EditorManager.java:972)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3563)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3212)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$33.runWithException(Workbench.java:1600)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2609)
at org.eclipse.bpmn2.modeler.ui.editor.BPMN2Editor.init(BPMN2Editor.java:301)
>>>>> When I start with manager (sudo) priveleges I get the error message on the file I had tried to create previously but can now create a new BPMN diagram.
Re: FIle access issue [message #921861 is a reply to message #920607] Mon, 24 September 2012 09:52 Go to previous messageGo to next message
Robert Brodt is currently offline Robert Brodt
Hi Grant,
The editor uses the system temp directory to create working files. Can you check if you have environment variables or Java options configured to specify a temp directory? Java options are set with _JAVA_OPTIONS environment variable, like so:
export _JAVA_OPTIONS=-Djava.io.tmpdir=/new/tmp/dir
Or they may be passed to the JRE on startup:
java -Djava.io.tmpdir=/path/to/tmpdir
Depending on which JRE you are using, you may also want to check your shell profile (.profile, .bashrc, etc.) and /etc/environment settings for TMPDIR environment variable settings.
Please let me know what you find out.
Thanks!
Bob
Re: FIle access issue [message #921958 is a reply to message #921861] Mon, 24 September 2012 11:42 Go to previous messageGo to next message
Found the problem and will have a fix shortly. Created a bugzilla to track this here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=390227
Re: FIle access issue [message #921986 is a reply to message #921958] Mon, 24 September 2012 12:15 Go to previous message
Hi all,
This issue should be fixed now. The latest builds are available from the update sites.
Cheers, and thanks for keeping me on my toes Wink
Bob
Previous Topic:Breaking changes in BPMN 2.0 Modeler latest version
Next Topic:Resizing of tasks not preserved on save
Current Time: Sun May 19 13:38:54 EDT 2013
Powered by FUDForum. Page generated in 0.01601 seconds
