Home » Newcomers » Newcomers » Git(Import project from Git)
Git [message #920179] Sat, 22 September 2012 16:39 Go to next message
Chris White is currently offline Chris White
I'm trying to import from Git.
I see several examples and looking at a video that it's File->Import->Git->Projects from Git.
I don't have that option. Git is not there.
Any ideas?
Juno on Windows 7 64bit
Re: Git [message #920192 is a reply to message #920179] Sat, 22 September 2012 16:57 Go to previous messageGo to next message
Russell Bateman is currently offline Russell Bateman
> Any ideas?
There are two options.
a) I use Git outside of Eclipse, via the command line--has nothing to do
with Eclipse. Works fine, not as convenient perhaps.
b) Install eGit (http://www.eclipse.org/egit/) and consume Git from
inside Eclipse (what you're trying to do, I think).
There is a separate forum for eGit questions, nntp is eclipse.egit.
You'll git lots more and better help there.
Re: Git [message #920203 is a reply to message #920192] Sat, 22 September 2012 17:18 Go to previous message
Thanks, EGit did the trick.
Previous Topic:After install, no run-as PHP Web Page
Next Topic:Create a zip file from source folder
Current Time: Sat May 25 11:43:18 EDT 2013
Powered by FUDForum. Page generated in 0.01475 seconds
