| Keep getting "error in children" [message #919735] |
Sat, 22 September 2012 05:23  |
Roger Gilliar Messages: 21 Registered: March 2010 |
Junior Member |
I just started to evaluate Jubula and until now I wasn't even able to run a simple test. The first time I tried a simple RCP test which didn't work and now a simple Swing test. I just have a very simple form that has 3 textfields and two button. If I click on the first button, textfield1 should be set to a certain value ('hello world' in this case). Since I had the same problem with RCP and Swing I think I must be doing something wrong.
BTW: Even recorded tests do not work.
The error messages I get are:
"Window activation failed" if I try to activate the window first or "timeout received before confirming the posted event" if I try to execute the click on the button before activating the form.
Roger
BTW: Im on Mac OSX 10.8.2 and Java 7
[Updated on: Sat, 22 September 2012 05:24] Report message to a moderator
FUDForum. Page generated in 0.01473 seconds
