Home » Eclipse Projects » scout » Change Mouse Pointer on AbstractTable
Change Mouse Pointer on AbstractTable [message #904907] Wed, 29 August 2012 07:11 Go to next message
Adrian Moser
Member
I have an instance of AbstractTable and I would like to change the default mouse pointer (cursor) on certain cells. Any suggestions?
Re: Change Mouse Pointer on AbstractTable [message #908008 is a reply to message #904907] Tue, 04 September 2012 10:40 Go to previous messageGo to next message
Ken Lee is currently offline Ken Lee
Member
Hi Adrian,
As discussed, since you need to provide a download URL inside a table in your Use Case,
you can create an AbstractStringColumn and emit your download location by encapsulating it between
<html>...</html>
The mouse cursor will change from an arrow to a hand. Between the HTML tag, you can simply write standard HTML code like
<a href="..."</a>
The parsing is done in RwtScoutTable in the method initializeUiColumns().
However, if you need a different mouse cursor for different table columns, it's currently not possible without changing the Scout code.
Ken
Re: Change Mouse Pointer on AbstractTable [message #918806 is a reply to message #908008] Fri, 21 September 2012 07:10 Go to previous message
Adrian Moser
Member
Thanks, Ken, that is exactly what I need.
The clicked URL can be further processed by implementing
AbstractTableField.execHyperlinkAction
Previous Topic:Activator in org.eclipse.scout.rt.server
Next Topic:SWT not recognizing changes in focused FormField
Current Time: Fri May 24 14:30:11 EDT 2013
Powered by FUDForum. Page generated in 0.08341 seconds
