Home » Eclipse Projects » Web Tools Project (WTP) » JSDT extending indexer(How to extend the jsdt indexer with special cases.)
JSDT extending indexer [message #916599] Wed, 19 September 2012 04:09 Go to next message
László Jánszky is currently offline László Jánszky
Hi!
I think lots of developers have a problem with the jsdt code assist:
The class definition and the inheritance working only this way:
var Ancestor = function (){};
Ancestor.prototype.x = function (a){};
var Descendant = new Ancestor();
Descendant.prototype.y = function (b){};
and we creating classes this way:
my custom lib
var Ancestor = Function.create({
	constructor: function (){},
	x: function (a){}
var Descendant = Ancestor.extend({
	y: function (b){}
mootools
var Ancestor = new Class({
	initialize: function (){},
	x: function (a){}
var Descendant = new Class({
	Extends: Ancestor,
	y: function (b){}
extjs
var Ancestor = Ext.extend(Object, {
	x: function (a){}
var Descendant = Ext.extend(Ancestor, {
	y: function (b){}
prototype.js
var Ancestor = Class.create({
	x: function (a){}
var Descendant = Class.create(Ancestor, {
	y: function (b){}
etc...
So everything is solved by class definition and inheritance, it works well, but we cannot use it because the InferEngine does not notice the patterns above...
I'm on creating a plugin which will be easy extendable with custom patterns, but I don't know which is the easiest way to make it. I mean there are too many options, for example: decorating the InferEngine or making a custom InferEngine and use both engines parallel or maybe the InferEngine has a plugable interface, so I can add these pattern without extending it (havent seen the code yet), etc...
What do you suggest?
The situation is more complicated because this text is by several classes in the documentation found here:
pic.dhe.ibm.com/infocenter/ratdevz/v7r5/index.jsp?topic=%2Forg.eclipse.wst.jsdt.doc%2Fhtml%2Fapi_reference%2Forg%2Feclipse%2Fwst%2Fjsdt%2Fweb%2Fcore%2Fjavascript%2Fsearch%2Fpackage-summary.html
Provisional API: This class/interface is part of an interim API that is still under development and expected to change significantly before reaching stability.
So I guess if I make a plugin it won't work by the next release... :S Is it possible to commit my changes on the InferEngine if you are satisfied with the code?
Re: JSDT extending indexer [message #916779 is a reply to message #916599] Wed, 19 September 2012 08:59 Go to previous messageGo to next message
I watched around and found that the real problem is, that there is no complete support of JSDOC 3 in the JSDT.
css.dzone.com/articles/introduction-jsdoc
Here is a tutorial of jsdoc, and @lends, @extends, @constructs are not supported yet...
Re: JSDT extending indexer [message #917082 is a reply to message #916599] Wed, 19 September 2012 16:00 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
I'd be a fool to say no to high quality patches that adhere to our vendor neutrality Smile
Nitin Dahyabhai
Eclipse WTP, IBM
Re: JSDT extending indexer [message #917933 is a reply to message #917082] Thu, 20 September 2012 11:19 Go to previous messageGo to next message
Okay. I have a project now for about 1 month, after that I'll contact you.
Re: JSDT extending indexer [message #918082 is a reply to message #917933] Thu, 20 September 2012 14:21 Go to previous messageGo to next message
sNop is currently offline sNop
Great, this are really good news, jsdt ca isn't good enough, compare to the other editors
Re: JSDT extending indexer [message #918117 is a reply to message #918082] Thu, 20 September 2012 15:06 Go to previous message
I don't think so. Only Jetbrains products (for example: WebStorm) are better, they support jsDoc 3, but they are not freeware. Aptana is similar, NetBeans weaker...
Previous Topic:WSDL error? XSD: The location has not been resolved
Next Topic:The User Operation is waiting for background work to complete
Current Time: Mon May 20 18:13:34 EDT 2013
Powered by FUDForum. Page generated in 0.04631 seconds
