| Renaming cross links [message #917899] |
Thu, 20 September 2012 10:48 |
Edwin Park Messages: 109 Registered: July 2009 |
I have an Xtext domain model that I would like to transform by renaming entities. However when I do this the cross-references to those renamed entities are broken.
This can be shown with the Xtext Domainmodel example. Below is a sample program that parses an instance of a Domainmodel and then serialized it back out to a file.
val model = parser.parse(
entity One {
entity Two {
first : One
val entityOne = model.elements.get(0) as Entity
model.eResource.save(new FileOutputStream("original.dmodel"), newHashMap)
/* result:
entity One {
entity Two {
first : One
So far, so good. The Xtext resource is serialized fine and the cross reference from the Two.first property correctly points to the entity One.
Now let's rename entity One to be called Uno instead:
entityOne.name = "Uno"
model.eResource.save(new FileOutputStream("transformed.dmodel"), newHashMap)
/* result:
entity Uno {
entity Two {
first : One
Now in the result the entity One has been renamed to Uno, but Two.first property is still pointing to an entity called One, which no longer exists.
What can I do to transform names in Xtext without breaking cross references this way?
Edwin
[Updated on: Thu, 11 October 2012 12:17] Report message to a moderator
FUDForum. Page generated in 0.02201 seconds
