Home » Eclipse Projects » BIRT » Grid in Grid / Grid height to Cell height
Grid in Grid / Grid height to Cell height [message #917797] Thu, 20 September 2012 08:47 Go to next message
Thomas Plorin is currently offline Thomas Plorin
I have a Report with Grid in Grid to Layout a given Design.
Ist there a way to define an inner grid, to grow to the whole heigth of cell height, where the grid is in?
See attached Reportdesign
The red grid should have the height of the blue cell. (of course expect borders, margins, etc.)
The effect should be, that the last row from the red grid should be as heigh as the leftover height of the contained cell. (the free blue area)
[Updated on: Thu, 20 September 2012 09:03]
Report message to a moderator
Re: Grid in Grid / Grid height to Cell height [message #917968 is a reply to message #917797] Thu, 20 September 2012 11:52 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
Have you tried setting the height of the red grid to 165 mm?
Jason
Jason Weathersby
BIRT Exchange
Re: Grid in Grid / Grid height to Cell height [message #918557 is a reply to message #917968] Fri, 21 September 2012 01:51 Go to previous messageGo to next message
I thought about this solution, but then I must always change the height if I change the sourrounding cell or row or table height. I hoped this could be done automaticly. I have tried 100% for this but it doesn't work.
Thomas
Re: Grid in Grid / Grid height to Cell height [message #919053 is a reply to message #918557] Fri, 21 September 2012 12:35 Go to previous message
You could log an enhancement request for thi. I did not 100% works fine in HTML. I assume the issue is with PDF.
Jason
Jason Weathersby
BIRT Exchange
Previous Topic:Possible to toggle visibility by clicking on another item?
Next Topic:Grouping multiple rows from result into single cell
Current Time: Sat May 18 09:54:14 EDT 2013
Powered by FUDForum. Page generated in 0.01578 seconds
