Home » Language IDEs » CDT » Still having an issue with the console output(Output with CDT not working.)
Still having an issue with the console output [message #916596] Wed, 19 September 2012 04:00 Go to next message
Steven Wirth is currently offline Steven Wirth
I am currently using 64bit Eclipse Juno with the newest version of CDT and MinGW. I have looked at a few other threads of people having this same problem where the console doesn't really display anything. I have a very simple program that I'm trying to get to work:
#include <stdio.h>
int main()
	int temp;
	printf("enter a number: ");
	scanf("%d", &temp);
		printf("%d", temp);
	return 0;
It says that the program is running after I hit run but it just sits there and doesn't print the initial "Enter a number: " but if I manually click on the console and put in a number it concludes the program successfully and shows me the output. I've already tried adding my MinGW\bin directory to both the PATH in windows and the individual project and I've also tried adding the "-static-libgcc" entry to the linker options as was suggested on another thread. Any ideas?
Re: Still having an issue with the console output [message #916713 is a reply to message #916596] Wed, 19 September 2012 06:54 Go to previous messageGo to next message
Joost Kraaijeveld is currently offline Joost Kraaijeveld
Did you have a look at:
http://wiki.eclipse.org/CDT/User/FAQ#Eclipse_console_does_not_show_output_on_Windows
Groeten,
Joost Kraaijeveld
Askesis B.V.
Molukkenstraat 14
6524NB Nijmegen
tel: 024-3888063 / 06-51855277
fax: 024-3608416
web: www.askesis.nl
Re: Still having an issue with the console output [message #916976 is a reply to message #916713] Wed, 19 September 2012 13:44 Go to previous message
Thanks that does seem to work. I was just hoping for a more permanent work around. Upon reading the comments under the bug entry that you linked though it doesn't seem like it is possible at the moment. Thanks again!
Previous Topic:Compiling patched code; Point cloud library (PCL)
Next Topic:Config complicated options in CDT Manage Build
Current Time: Sun May 19 06:18:04 EDT 2013
Powered by FUDForum. Page generated in 0.02042 seconds
