Home » Eclipse Projects » BIRT » switch from 2.3.0 to 2.3.1, "Processing please wait" never ends in jboss birt runtime
switch from 2.3.0 to 2.3.1, "Processing please wait" never ends in jboss birt runtime [message #365365] Tue, 30 September 2008 09:47 Go to next message
claus is currently offline claus
today i updated my birt environment from 2.3.0 to 2.3.1 using eclipse
update function on WinXP (Client). Execution of the "test.rptdesign" works.
Then i downloaded the 2.3.1 runtime to deploy it on the jboss webserver
(version 4.2.3.GA) running on RHEL 5.2 64-bit. (Deployment as described
for jboss on the BIRT website
http://www.eclipse.org/birt/phoenix/deploy/viewerSetup.php ). (With
version 2.3.0 the "test.rptdesign" (and other reports) are running
without that problem).
Using the link http://192.168.1.1:8081/birt/run?__report=test.rptdesign
within Internet Explorer 7, the content of the report is returned as
expected. But the "Processing, please wait..." window is not closed
(still keeps working).
The same thing happens with other reports.
Using the link
http://192.168.1.1:8081/birt/frameset?__report=test.rptdesig n results in
the following HTTP Status 500:
exception
org.apache.jasper.JasperException: javax.servlet.ServletException:
java.lang.NoSuchMethodError:
org.eclipse.birt.report.utility.ParameterAccessor.getEncoded QueryString(Ljavax/servlet/http/HttpServletRequest;Ljava/lan g/String;Ljava/lang/String;)Ljava/lang/String;
org.apache.jasper.servlet.JspServletWrapper.handleJspExcepti on(JspServletWrapper.java:521)
org.apache.jasper.servlet.JspServletWrapper.service(JspServl etWrapper.java:397)
org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServl et.java:336)
org.apache.jasper.servlet.JspServlet.service(JspServlet.java :265)
javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
org.eclipse.birt.report.presentation.aggregation.AbstractBas eFragment.service(AbstractBaseFragment.java:82)
org.eclipse.birt.report.presentation.aggregation.AbstractBas eFragment.callBack(AbstractBaseFragment.java:106)
org.apache.jsp.webcontent.birt.pages.layout.FramesetFragment _jsp._jspService(FramesetFragment_jsp.java:263)
org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.ja va:70)
org.apache.jasper.servlet.JspServletWrapper.service(JspServl etWrapper.java:373)
org.eclipse.birt.report.presentation.aggregation.layout.Fram esetFragment.service(FramesetFragment.java:98)
org.eclipse.birt.report.servlet.ViewerServlet.__doGet(Viewer Servlet.java:181)
org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doGet(BirtSoapMessageDispatcherServlet.java:146)
javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.service(BirtSoapMessageDispatcherServlet.java:112)
org.eclipse.birt.report.filter.ViewerFilter.doFilter(ViewerF ilter.java:68)
org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(Repl yHeaderFilter.java:96)
root cause
javax.servlet.ServletException: java.lang.NoSuchMethodError:
org.apache.jasper.runtime.PageContextImpl.doHandlePageExcept ion(PageContextImpl.java:850)
org.apache.jasper.runtime.PageContextImpl.handlePageExceptio n(PageContextImpl.java:779)
org.apache.jsp.webcontent.birt.pages.control.ToolbarFragment _jsp._jspService(ToolbarFragment_jsp.java:220)
root cause
org.apache.jsp.webcontent.birt.pages.control.ToolbarFragment _jsp._jspService(ToolbarFragment_jsp.java:82)
Any ideas how to solve the problem?
Thanks in advance
claus
Re: switch from 2.3.0 to 2.3.1, "Processing please wait" never ends in jboss birt runtime [message #365372 is a reply to message #365365] Tue, 30 September 2008 13:22 Go to previous messageGo to next message
Eclipse User
Claus,
Can you set the log level to FINE and then post the log file for the
runtime?
Jason
exquisitus wrote:
> Using the link
> exception
> root cause
> root cause
> Thanks in advance
> claus
Re: switch from 2.3.0 to 2.3.1, "Processing please wait" never ends in jboss birt runtime [message #365384 is a reply to message #365372] Wed, 01 October 2008 03:07 Go to previous messageGo to next message
Good morning,
following the BIRT logfile from ../birt.war/logs after accessing the
following link:
There is one thing i forgot in the first post. I'm using jdk1.6.0_07 on
the linux server.
claus
Startlog ===>
01.10.2008 08:53:44 org.eclipse.birt.report.engine.api.impl.ReportEngine
<init>
FEIN: ReportEngine created. EngineConfig: EngineConfig:
org.eclipse.birt.report.engine.api.EngineConfig.scriptObject s={PARENT_CLASSLOADER=WebappClassLoader
delegate: false
repositories:
----------> Parent Classloader:
java.net.FactoryURLClassLoader@741378ec
webapplication.projectclasspath=};maxRowsPerQuery=-1;BIRT_HO ME=;logLevel=FINE;PLATFORM_CONTEXT=org.eclipse.birt.core.framework.PlatformServletContext@7f0b8d03 ;org.eclipse.birt.report.engine.api.EngineConfig.emitterConf igs={html=org.eclipse.birt.report.engine.api.HTMLRenderOption@4f57011e };logDest=/opt/jboss/jboss-4.2.3.GA/server/default/./deploy/ birt.war/logs;
01.10.2008 08:53:44
org.eclipse.birt.report.engine.extension.internal.ExtensionM anager
getExtensions
FEIN: Start load extension point:
org.eclipse.birt.report.engine.reportitemGeneration
01.10.2008 08:53:44
loadGenerationExtensionDefns
FEIN: Load generation extension: Chart
01.10.2008 08:53:44
getExtensions
org.eclipse.birt.report.engine.reportitemPresentation
01.10.2008 08:53:44
loadPresentationExtensionDefns
FEIN: Load prsentation extension: Chart
01.10.2008 08:53:44
getExtensions
org.eclipse.birt.report.engine.reportitemQuery
01.10.2008 08:53:44
loadQueryExtensionDefns
FEIN: Load query extension: Chart
01.10.2008 08:53:44
getExtensions
FEIN: Start load extension point: org.eclipse.birt.report.engine.emitters
01.10.2008 08:53:44
loadEmitterExtensionDefns
FEIN: Load postscript emitter
org.eclipse.birt.report.engine.emitter.postscript
01.10.2008 08:53:44
FEIN: Load ppt emitter org.eclipse.birt.report.engine.emitter.ppt
01.10.2008 08:53:44
FEIN: Load html emitter org.eclipse.birt.report.engine.emitter.html
01.10.2008 08:53:44
FEIN: Load doc emitter org.eclipse.birt.report.engine.emitter.word
01.10.2008 08:53:44
FEIN: Load pdf emitter org.eclipse.birt.report.engine.emitter.pdf
01.10.2008 08:53:44
FEIN: Load xls emitter
org.eclipse.birt.report.engine.emitter.prototype.excel
01.10.2008 08:53:44
getExtensions
org.eclipse.birt.report.engine.reportEventHandler
01.10.2008 08:53:44
getExtensions
org.eclipse.birt.report.engine.reportItemPreparation
01.10.2008 08:53:44
getExtensions
org.eclipse.birt.report.engine.dataExtraction
01.10.2008 08:53:44
loadDataExtractionExtensions
FEIN: Load data extraction extension:
org.eclipse.birt.report.engine.dataextraction.csv
01.10.2008 08:53:44
getExtensions
org.eclipse.birt.report.engine.extendedItemFactory
01.10.2008 08:53:44
loadExtendedItems
FEIN: Load extendedItem extension: Crosstab
01.10.2008 08:53:44
loadExtendedItems
FEIN: Load extendedItem extension: CrosstabCell
01.10.2008 08:53:44
loadExtendedItems
FEIN: Load extendedItem extension: AggregationCell
01.10.2008 08:54:41 org.eclipse.birt.report.engine.api.impl.ReportEngine
openReportDocument
FEIN: ReportEngine.openReportDocument:
systemId=/opt/jboss/jboss-4.2.3.GA/server/default/./deploy/b irt.war/test.rptdesign,
file=/opt/jboss/jboss-4.2.3.GA/server/default/./deploy/birt. war/documents/BIRTDOCEF0F62E9CAF8C65A5C23A71D6F5341AF/9d4fb9 49/test.rptdocument,
options={resourceFolder=/opt/jboss/jboss-4.2.3.GA/server/def ault/./deploy/birt.war,
semanticCheck=false}
openReportDesign
FEIN: ReportEngine.openReportDesign:
name=file:/opt/jboss/jboss-4.2.3.GA/server/default/./deploy/ birt.war/test.rptdesign,
designStream=java.io.FileInputStream@7d94a8eb, options={3}
01.10.2008 08:54:41
org.eclipse.birt.report.model.metadata.ChoicePropertyType validateXml
FEIN: return internal name for choice eq
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return internal name for choice asc
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return internal name for choice DataSet
01.10.2008 08:54:41
FEIN: return internal name for choice hide
01.10.2008 08:54:41
FEIN: return internal name for choice string
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return internal name for choice any
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return internal name for choice if-realized
01.10.2008 08:54:41
FEIN: return internal name for choice auto
01.10.2008 08:54:41
FEIN: return internal name for choice hyperlink
01.10.2008 08:54:41
FEIN: return internal name for choice inner
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return internal name for choice auto layout
01.10.2008 08:54:41
FEIN: return internal name for choice ltr
01.10.2008 08:54:41
FEIN: return internal name for choice NoChange
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return internal name for choice static
01.10.2008 08:54:41
FEIN: return internal name for choice simple
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return internal name for choice single
01.10.2008 08:54:41
FEIN: return internal name for choice normal
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return internal name for choice none
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return internal name for choice scroll
01.10.2008 08:54:41
org.eclipse.birt.report.model.metadata.DimensionPropertyType validateXml
FEIN: return dimension value with default unit 0.0
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return internal name for choice repeat
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return internal name for choice block
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return dimension value with default unit 1.0
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return dimension value with default unit 1.25
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return dimension value with default unit 0.5
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return internal name for choice size-to-image
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return internal name for choice horizontal
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return internal name for choice sum
01.10.2008 08:54:41
FEIN: return internal name for choice decimal
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return dimension value with user defined unit 0%
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return dimension value with user defined unit 0em
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return dimension value with user defined unit 0pt
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return dimension value with user defined unit 1pt
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return dimension value with user defined unit 1in
01.10.2008 08:54:41
FEIN: return dimension value with user defined unit 1.25in
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return dimension value with user defined unit 0.5in
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return dimension value with user defined unit 0.5pt
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return internal name for choice over then down
01.10.2008 08:54:41
validateInputString
FEIN: Return internal name of the choice solid
01.10.2008 08:54:41
validateInputString
FEIN: return dimension with user-defined unit 1pt
01.10.2008 08:54:41
org.eclipse.birt.report.model.metadata.ColorPropertyType validateValue
FEIN: the validated color value 13421772
01.10.2008 08:54:41
validateInputString
01.10.2008 08:54:41
validateInputString
01.10.2008 08:54:41
01.10.2008 08:54:41
validateInputString
01.10.2008 08:54:41
validateInputString
01.10.2008 08:54:41
01.10.2008 08:54:41
validateInputString
01.10.2008 08:54:41
validateInputString
01.10.2008 08:54:41
01.10.2008 08:54:41
validateInputString
01.10.2008 08:54:41
validateInputString
01.10.2008 08:54:41
01.10.2008 08:54:41
validateInputString
01.10.2008 08:54:41
validateInputString
01.10.2008 08:54:41
01.10.2008 08:54:41
validateInputString
01.10.2008 08:54:41
validateInputString
01.10.2008 08:54:41
01.10.2008 08:54:41
validateInputString
01.10.2008 08:54:41
validateInputString
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return internal name for choice after
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:42
01.10.2008 08:54:42
FEIN: return internal name for choice text-box
01.10.2008 08:54:42
FEIN: return dimension value with user defined unit 100%
01.10.2008 08:54:42
FEIN: return internal name for choice bold
01.10.2008 08:54:42
FEIN: return internal name for choice center
01.10.2008 08:54:42
01.10.2008 08:54:42
FEIN: return internal name for choice html
01.10.2008 08:54:42
FEIN: return internal name for choice right
01.10.2008 08:54:42
FEIN: return internal name for choice page-number
01.10.2008 08:54:42
01.10.2008 08:54:42
01.10.2008 08:54:42
FEIN: return dimension value with user defined unit 1.354in
01.10.2008 08:54:42
FEIN: return dimension value with user defined unit 5.083in
01.10.2008 08:54:42 org.eclipse.birt.report.engine.api.impl.ReportEngine
createGetParameterDefinitionTask
FEIN: ReportEngine.createGetParameterDefinitionTask:
reportRunnable=org.eclipse.birt.report.engine.api.impl.ReportRunnable@1ac8210
01.10.2008 08:54:42 org.eclipse.birt.report.engine.api.impl.EngineTask
setAppContext
FEIN: EngineTask.setAppContext: context=PARENT_CLASSLOADER=WebappClassLoader
delegate: false
repositories:
;webapplication.projectclasspath=;
setLocale
FEIN: EngineTask.setLocale: locale=Deutsch
setAppContext
delegate: false
repositories:
;CHART_RESOLUTION=null;org.eclipse.birt.data.engine.dataset. cache.option=false;org.eclipse.birt.data.engine.cube.inmemor y.size=0;webapplication.projectclasspath=;BIRT_VIEWER_HTTPSE RVET_REQUEST=org.apache.catalina.connector.RequestFacade@1051f982 ;birt.viewer.resource.path=/opt/jboss/jboss-4.2.3.GA/server/ default/./deploy/birt.war;
setAppContext
delegate: false
repositories:
;webapplication.projectclasspath=;BIRT_VIEWER_HTTPSERVET_REQ UEST=org.apache.catalina.connector.RequestFacade@1051f982;
setAppContext
delegate: false
repositories:
setLocale
setAppContext
delegate: false
repositories:
setAppContext
delegate: false
repositories:
<=== Endlog
Jason Weathersby schrieb:
> Claus,
> runtime?
> Jason
> exquisitus wrote:
>> works.
>> webserver (version 4.2.3.GA) running on RHEL 5.2 64-bit. (Deployment
>> as described for jboss on the BIRT website
>> Using the link
>> http://192.168.1.1:8081/birt/run?__report=test.rptdesign within
>> Using the link
>> in the following HTTP Status 500:
>> exception
>> root cause
>> root cause
>> Thanks in advance
>> claus
Re: switch from 2.3.0 to 2.3.1, "Processing please wait" never ends in jboss birt runtime [message #365390 is a reply to message #365384] Wed, 01 October 2008 09:09 Go to previous messageGo to next message
the same error occurs using java version jdk1.5.0_16 .
claus
exquisitus schrieb:
> Good morning,
> following link:
> the linux server.
> Regards
> claus
> Startlog ===>
> <init>
> delegate: false
> repositories:
> 01.10.2008 08:53:44
> getExtensions
> 01.10.2008 08:53:44
> 01.10.2008 08:53:44
> getExtensions
> 01.10.2008 08:53:44
> 01.10.2008 08:53:44
> getExtensions
> 01.10.2008 08:53:44
> 01.10.2008 08:53:44
> getExtensions
> 01.10.2008 08:53:44
> 01.10.2008 08:53:44
> 01.10.2008 08:53:44
> 01.10.2008 08:53:44
> 01.10.2008 08:53:44
> 01.10.2008 08:53:44
> 01.10.2008 08:53:44
> getExtensions
> 01.10.2008 08:53:44
> getExtensions
> 01.10.2008 08:53:44
> getExtensions
> 01.10.2008 08:53:44
> 01.10.2008 08:53:44
> getExtensions
> 01.10.2008 08:53:44
> loadExtendedItems
> 01.10.2008 08:53:44
> loadExtendedItems
> 01.10.2008 08:53:44
> loadExtendedItems
> openReportDocument
> openReportDesign
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> validateInputString
> 01.10.2008 08:54:41
> validateInputString
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> validateInputString
> 01.10.2008 08:54:41
> validateInputString
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> validateInputString
> 01.10.2008 08:54:41
> validateInputString
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> validateInputString
> 01.10.2008 08:54:41
> validateInputString
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> validateInputString
> 01.10.2008 08:54:41
> validateInputString
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> validateInputString
> 01.10.2008 08:54:41
> validateInputString
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> validateInputString
> 01.10.2008 08:54:41
> validateInputString
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> validateInputString
> 01.10.2008 08:54:41
> validateInputString
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:42
> 01.10.2008 08:54:42
> 01.10.2008 08:54:42
> 01.10.2008 08:54:42
> 01.10.2008 08:54:42
> 01.10.2008 08:54:42
> 01.10.2008 08:54:42
> 01.10.2008 08:54:42
> 01.10.2008 08:54:42
> 01.10.2008 08:54:42
> 01.10.2008 08:54:42
> 01.10.2008 08:54:42
> 01.10.2008 08:54:42
> setAppContext
> delegate: false
> repositories:
> setLocale
> setAppContext
> delegate: false
> repositories:
> setAppContext
> delegate: false
> repositories:
> setAppContext
> delegate: false
> repositories:
> setLocale
> setAppContext
> delegate: false
> repositories:
> setAppContext
> delegate: false
> repositories:
> <=== Endlog
>> Claus,
>> runtime?
>> Jason
>> exquisitus wrote:
>>> Hi,
>>> works.
>>> Using the link
>>> Using the link
>>> exception
>>> root cause
>>> root cause
Re: switch from 2.3.0 to 2.3.1, "Processing please wait" never ends in jboss birt runtime [message #365396 is a reply to message #365390] Wed, 01 October 2008 11:09 Go to previous messageGo to next message
Eclipse User
Claus,
You may need to log a bug for this, but can you try to war the
WebViewerExample directory and use it instead of the birt.war?
Jason
exquisitus wrote:
> claus
> exquisitus schrieb:
>> Good morning,
>> following link:
>> on the linux server.
>> Regards
>> claus
>> Startlog ===>
>> 01.10.2008 08:53:44
>> org.eclipse.birt.report.engine.api.impl.ReportEngine <init>
>> delegate: false
>> repositories:
>> 01.10.2008 08:53:44
>> getExtensions
>> 01.10.2008 08:53:44
>> 01.10.2008 08:53:44
>> getExtensions
>> 01.10.2008 08:53:44
>> 01.10.2008 08:53:44
>> getExtensions
>> 01.10.2008 08:53:44
>> 01.10.2008 08:53:44
>> getExtensions
>> 01.10.2008 08:53:44
>> 01.10.2008 08:53:44
>> 01.10.2008 08:53:44
>> 01.10.2008 08:53:44
>> 01.10.2008 08:53:44
>> 01.10.2008 08:53:44
>> 01.10.2008 08:53:44
>> getExtensions
>> 01.10.2008 08:53:44
>> getExtensions
>> 01.10.2008 08:53:44
>> getExtensions
>> 01.10.2008 08:53:44
>> 01.10.2008 08:53:44
>> getExtensions
>> 01.10.2008 08:53:44
>> loadExtendedItems
>> 01.10.2008 08:53:44
>> loadExtendedItems
>> 01.10.2008 08:53:44
>> loadExtendedItems
>> 01.10.2008 08:54:41
>> org.eclipse.birt.report.engine.api.impl.ReportEngine openReportDocument
>> 01.10.2008 08:54:41
>> org.eclipse.birt.report.engine.api.impl.ReportEngine openReportDesign
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> validateInputString
>> 01.10.2008 08:54:41
>> validateInputString
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> validateInputString
>> 01.10.2008 08:54:41
>> validateInputString
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> validateInputString
>> 01.10.2008 08:54:41
>> validateInputString
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> validateInputString
>> 01.10.2008 08:54:41
>> validateInputString
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> validateInputString
>> 01.10.2008 08:54:41
>> validateInputString
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> validateInputString
>> 01.10.2008 08:54:41
>> validateInputString
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> validateInputString
>> 01.10.2008 08:54:41
>> validateInputString
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> validateInputString
>> 01.10.2008 08:54:41
>> validateInputString
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:42
>> 01.10.2008 08:54:42
>> 01.10.2008 08:54:42
>> 01.10.2008 08:54:42
>> 01.10.2008 08:54:42
>> 01.10.2008 08:54:42
>> 01.10.2008 08:54:42
>> 01.10.2008 08:54:42
>> 01.10.2008 08:54:42
>> 01.10.2008 08:54:42
>> 01.10.2008 08:54:42
>> 01.10.2008 08:54:42
>> 01.10.2008 08:54:42
>> 01.10.2008 08:54:42
>> setAppContext
>> delegate: false
>> repositories:
>> setLocale
>> setAppContext
>> delegate: false
>> repositories:
>> setAppContext
>> delegate: false
>> repositories:
>> 01.10.2008 08:54:42
>> setAppContext
>> delegate: false
>> repositories:
>> setLocale
>> setAppContext
>> delegate: false
>> repositories:
>> setAppContext
>> delegate: false
>> repositories:
>> <=== Endlog
>>> Claus,
>>> runtime?
>>> Jason
>>> exquisitus wrote:
>>>> Hi,
>>>> eclipse update function on WinXP (Client). Execution of the
>>>> Using the link
>>>> Using the link
>>>> results in the following HTTP Status 500:
>>>> exception
>>>> root cause
>>>> org.ec
Re: switch from 2.3.0 to 2.3.1, "Processing please wait" never ends in jboss birt runtime [message #365398 is a reply to message #365396] Wed, 01 October 2008 11:47 Go to previous messageGo to next message
Hi Jason,
as in the install / deployment documentation for jboss mentioned,
war'ing the WebViewerExample is what i did.
I will try to deploy the "pure" birt.war and doublecheck that.
As a workaround, I installed jboss-web and copied the birt.war folder
from the jboss application server. There the test report and some others
work fine.
claus
> Claus,
> Jason
> exquisitus wrote:
>> claus
>> exquisitus schrieb:
>>> Good morning,
>>> following link:
>>> Regards
>>> claus
>>> Startlog ===>
>>> 01.10.2008 08:53:44
>>> delegate: false
>>> repositories:
>>> 01.10.2008 08:53:44
>>> getExtensions
>>> 01.10.2008 08:53:44
>>> 01.10.2008 08:53:44
>>> getExtensions
>>> 01.10.2008 08:53:44
>>> 01.10.2008 08:53:44
>>> getExtensions
>>> 01.10.2008 08:53:44
>>> 01.10.2008 08:53:44
>>> getExtensions
>>> 01.10.2008 08:53:44
>>> 01.10.2008 08:53:44
>>> 01.10.2008 08:53:44
>>> 01.10.2008 08:53:44
>>> 01.10.2008 08:53:44
>>> 01.10.2008 08:53:44
>>> 01.10.2008 08:53:44
>>> getExtensions
>>> 01.10.2008 08:53:44
>>> getExtensions
>>> 01.10.2008 08:53:44
>>> getExtensions
>>> 01.10.2008 08:53:44
>>> 01.10.2008 08:53:44
>>> getExtensions
>>> 01.10.2008 08:53:44
>>> loadExtendedItems
>>> 01.10.2008 08:53:44
>>> loadExtendedItems
>>> 01.10.2008 08:53:44
>>> loadExtendedItems
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> validateInputString
>>> 01.10.2008 08:54:41
>>> validateInputString
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> validateInputString
>>> 01.10.2008 08:54:41
>>> validateInputString
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> validateInputString
>>> 01.10.2008 08:54:41
>>> validateInputString
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> validateInputString
>>> 01.10.2008 08:54:41
>>> validateInputString
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> validateInputString
>>> 01.10.2008 08:54:41
>>> validateInputString
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> validateInputString
>>> 01.10.2008 08:54:41
>>> validateInputString
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> validateInputString
>>> 01.10.2008 08:54:41
>>> validateInputString
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> validateInputString
>>> 01.10.2008 08:54:41
>>> validateInputString
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:42
>>> 01.10.2008 08:54:42
>>> 01.10.2008 08:54:42
>>> 01.10.2008 08:54:42
>>> 01.10.2008 08:54:42
>>> 01.10.2008 08:54:42
>>> 01.10.2008 08:54:42
>>> 01.10.2008 08:54:42
>>> 01.10.2008 08:54:42
>>> 01.10.2008 08:54:42
>>> 01.10.2008 08:54:42
>>> 01.10.2008 08:54:42
>>> 01.10.2008 08:54:42
>>> 01.10.2008 08:54:42
>>> 01.10.2008 08:54:42
>>> org.eclipse.birt.report.engine.api.impl.EngineTask setAppContext
>>> delegate: false
>>> repositories:
>>> 01.10.2008 08:54:42
>>> org.eclipse.birt.report.engine.api.impl.EngineTask setLocale
>>> 01.10.2008 08:54:42
>>> delegate: false
>>> repositories:
>>> 01.10.2008 08:54:42
>>> delegate: false
>>> repositories:
>>> 01.10.2008 08:54:42
>>> 01.10.2008 08:54:42
>>> delegate: false
>>> repositories:
>>> 01.10.2008 08:54:42
>>> 01.10.2008 08:54:42
>>> delegate: false
>>> repositories:
>>> 01.10.2008 08:54:42
>>> delegate: false
>>> repositories:
>>> <=== Endlog
>>>> Claus,
>>>> runtime?
>>>> Jason
>>>> exquisitus wrote:
>>>>> Hi,
>>>>> (Deployment as described for jboss on the BIRT website
>>>>> Using the link
>>>>> Using the link
>>>>> exception
Re: switch from 2.3.0 to 2.3.1, "Processing please wait" never ends in jboss birt runtime [message #365420 is a reply to message #365398] Thu, 02 October 2008 05:09 Go to previous messageGo to next message
tested the delivered birt.war. The same error occurs.
claus
exquisitus schrieb:
> Hi Jason,
> work fine.
> claus
>> Claus,
>> Jason
>> exquisitus wrote:
>>> Hi,
>>> claus
>>> exquisitus schrieb:
>>>> Good morning,
>>>> following link:
>>>> Regards
>>>> claus
>>>> Startlog ===>
>>>> 01.10.2008 08:53:44
>>>> delegate: false
>>>> repositories:
>>>> 01.10.2008 08:53:44
>>>> getExtensions
>>>> 01.10.2008 08:53:44
>>>> 01.10.2008 08:53:44
>>>> getExtensions
>>>> 01.10.2008 08:53:44
>>>> 01.10.2008 08:53:44
>>>> getExtensions
>>>> 01.10.2008 08:53:44
>>>> 01.10.2008 08:53:44
>>>> getExtensions
>>>> 01.10.2008 08:53:44
>>>> 01.10.2008 08:53:44
>>>> 01.10.2008 08:53:44
>>>> 01.10.2008 08:53:44
>>>> 01.10.2008 08:53:44
>>>> 01.10.2008 08:53:44
>>>> 01.10.2008 08:53:44
>>>> getExtensions
>>>> 01.10.2008 08:53:44
>>>> getExtensions
>>>> 01.10.2008 08:53:44
>>>> getExtensions
>>>> 01.10.2008 08:53:44
>>>> 01.10.2008 08:53:44
>>>> getExtensions
>>>> 01.10.2008 08:53:44
>>>> loadExtendedItems
>>>> 01.10.2008 08:53:44
>>>> loadExtendedItems
>>>> 01.10.2008 08:53:44
>>>> loadExtendedItems
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> validateInputString
>>>> 01.10.2008 08:54:41
>>>> validateInputString
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> validateInputString
>>>> 01.10.2008 08:54:41
>>>> validateInputString
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> validateInputString
>>>> 01.10.2008 08:54:41
>>>> validateInputString
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> validateInputString
>>>> 01.10.2008 08:54:41
>>>> validateInputString
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> validateInputString
>>>> 01.10.2008 08:54:41
>>>> validateInputString
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> validateInputString
>>>> 01.10.2008 08:54:41
>>>> validateInputString
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> validateInputString
>>>> 01.10.2008 08:54:41
>>>> validateInputString
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> validateInputString
>>>> 01.10.2008 08:54:41
>>>> validateInputString
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:42
>>>> 01.10.2008 08:54:42
>>>> 01.10.2008 08:54:42
>>>> validateXml
>>>> 01.10.2008 08:54:42
>>>> 01.10.2008 08:54:42
>>>> 01.10.2008 08:54:42
>>>> validateXml
>>>> 01.10.2008 08:54:42
>>>> 01.10.2008 08:54:42
>>>> 01.10.2008 08:54:42
>>>> 01.10.2008 08:54:42
>>>> 01.10.2008 08:54:42
>>>> validateXml
>>>> 01.10.2008 08:54:42
>>>> validateXml
>>>> 01.10.2008 08:54:42
>>>> validateXml
>>>> 01.10.2008 08:54:42
>>>> 01.10.2008 08:54:42
>>>> delegate: false
>>>> repositories:
>>>> 01.10.2008 08:54:42
>>>> 01.10.2008 08:54:42
>>>> delegate: false
>>>> repositories:
>>>> 01.10.2008 08:54:42
>>>> delegate: false
>>>> repositories:
>>>> 01.10.2008 08:54:42
>>>> 01.10.2008 08:54:42
>>>> delegate: false
>>>> repositories:
>>>> 01.10.2008 08:54:42
>>>> 01.10.2008 08:54:42
>>>> delegate: false
>>>> repositories:
>>>> 01.10.2008 08:54:42
>>>> delegate: false
>>>> repositories:
>>>> <=== Endlog
>>>>> Claus,
Re: switch from 2.3.0 to 2.3.1, "Processing please wait" never ends in jboss birt runtime [message #366083 is a reply to message #365365] Thu, 27 November 2008 08:07 Go to previous messageGo to next message
Sebastian Schneider is currently offline Sebastian Schneider
Hi Claus,
I had the same problem today and I solved the problem by deleting the
folder "tmp" and "work" under server/default/deploy/ in the JBoss
application server.
In my case, the .java and .class files, the JBoss Web-Container creates
out of the .jsp files of the WebViewer were not recreated by the
deployment and so still were those of BIRT 2.3.0 instead of 2.3.1, which
lead to the same Exception you are getting.
If you delete the "tmp" and "work" folders, the application should run
without any problems.
Greetings,
Sebastian
Re: switch from 2.3.0 to 2.3.1, "Processing please wait" never ends in jboss birt runtime [message #916625 is a reply to message #366083] Wed, 19 September 2012 04:40 Go to previous message
David Good is currently offline David Good
Member
Thanks Sebastian,
Today I upgraded from runtime 2.5 to 4.02 and had major issues with the frameset and the session error mentioned in this post.
Deleting the work folder alone did not work, deleting BOTH the tmp and work folders (on Tomcat 7) did the trick!
Dave
Previous Topic:Cross Tab export to dataSet
Next Topic:Consolidating table rows on some conditions
Current Time: Sat May 25 18:14:37 EDT 2013
Powered by FUDForum. Page generated in 0.02298 seconds
