Home » Language IDEs » CDT » Eclipse C++ project begins with error tag in project explorer(Unable to get CDT to work properly)
Eclipse C++ project begins with error tag in project explorer [message #916426] Tue, 18 September 2012 22:11 Go to next message
Peter Baldwin is currently offline Peter Baldwin
Just installed CDT for Eclipse juno.
Installed MinGW.
Switched to workspace "C:\EclipseWorkspaces\csse120".
installed a preferences folder "EclipsePreference-2011-06.epf)" which I imported.
then...
file --> New --> C project / project type: Executable (Hello world ANSI C) / Toolchain: MinGW GCC --> finish.
When I tried to Run As ... "Launched failed. Binary not found."
What do I do ??????
PLEASE HELP!
Re: Eclipse C++ project begins with error tag in project explorer [message #916462 is a reply to message #916426] Tue, 18 September 2012 23:25 Go to previous messageGo to next message
David Wegener is currently offline David Wegener
> Installed MinGW.
> imported.
> then...
> What do I do ?????? PLEASE HELP!
Did you build the project? You have to build in order to get a binary
to execute.
Re: Eclipse C++ project begins with error tag in project explorer [message #916477 is a reply to message #916462] Tue, 18 September 2012 23:58 Go to previous message
Thanks for the reply,
I had not built the project yet...
After build:
I clicked Run As
Window pop-up:
Problem Occured
'Launching Greetings Debug' has encountered a problem.
A program file was not specified in the launch configuration.
I looked through "Configurations --> Manage", and some other options to no avail.
Previous Topic:Why are warnings marked as errors?
Next Topic:Eclipse C++ No Debuginfos
Current Time: Sun May 19 05:09:58 EDT 2013
Powered by FUDForum. Page generated in 0.01863 seconds
