Home » Eclipse Projects » Web Tools Project (WTP) » WSDLReader & XML catalog for imported schemas
WSDLReader & XML catalog for imported schemas [message #916254] Tue, 18 September 2012 16:13
e fergus is currently offline e fergus
Hi all,
I'm using Eclipse WTP to read a WSDL file, parse the schema, and import schema dependencies by calling
WSDLReader.readWSDL(myWSDL)
The particular WSDL I'm looking at has a schema which imports the soap-encoding schema, which is provided in my XML catalog from the org.eclipse.wst.standard.schemas plugin. If I run Eclipse using the HTTP Connection Tracer, I see that this schema is being grabbed from the url and not the catalog.
Do I have to specify some parameter in order to use the XML catalog?
I'm using Eclipse 3.6.2 with WTP 3.2.3.
Thanks!
Previous Topic:Is any documentation to plugin org.eclipse.jst.pagedesigner exist?
Next Topic:WSDL error? XSD: The location has not been resolved
Current Time: Mon May 20 20:49:24 EDT 2013
Powered by FUDForum. Page generated in 0.01497 seconds
