| AJDT slooooow/hanging on clean rebuild [message #915581] |
Mon, 17 September 2012 11:20  |
Gerolf Scherr Messages: 1 Registered: December 2009 |
Junior Member |
I have a workspace with two java/aspectj-projects, when I am doing a project clean/rebuild, sometimes it needs around 30 sec, sometimes it 'hangs' for more than 10 minutes, when I terminate the program and restart it, the build works.
I have done several thread dumps (approx. one per minute) of one of the hanging runs. (see attachments)
I am not sure if this is a Problem in AJDT or some kind of deadlock.
I am using juno:
Eclipse Juno, Build id: 20120614-1722
AJDT-Version:
16:58:51 Startup information:
AJDT version: 2.2.0.e42x-RELEASE-20120703-2200
AspectJ Compiler version: 1.7.0
usingVisualiser=true
usingXref=true
usingCUprovider=true
ajde.version.at.previous.startup = 2.2.0.e42x-RELEASE-20120703-2200
thanks a lot for your help.
This thread is always busy:
at org.eclipse.core.internal.resources.AliasManager$2.compare(AliasManager.java:1)
at java.util.TreeMap.getEntryUsingComparator(Unknown Source)
at java.util.TreeMap.getEntry(Unknown Source)
at java.util.TreeMap.get(Unknown Source)
at org.eclipse.core.internal.resources.AliasManager$LocationMap.matchingResourcesDo(AliasManager.java:196)
at org.eclipse.core.internal.resources.AliasManager.findResources(AliasManager.java:446)
at org.eclipse.core.internal.localstore.FileSystemResourceManager.findLinkedResourcesPaths(FileSystemResourceManager.java:144)
at org.eclipse.core.internal.localstore.FileSystemResourceManager.allPathsForLocationNonCanonical(FileSystemResourceManager.java:124)
at org.eclipse.core.internal.localstore.FileSystemResourceManager.allPathsForLocation(FileSystemResourceManager.java:62)
at org.eclipse.core.internal.localstore.FileSystemResourceManager.allResourcesFor(FileSystemResourceManager.java:216)
at org.eclipse.core.internal.resources.WorkspaceRoot.findFilesForLocationURI(WorkspaceRoot.java:113)
at org.eclipse.core.internal.resources.WorkspaceRoot.findFilesForLocationURI(WorkspaceRoot.java:104)
at org.eclipse.ajdt.internal.utils.AJDTUtils.findResource(AJDTUtils.java:1217)
at org.eclipse.ajdt.internal.ui.ajde.UIMessageHandler.locationToResource(UIMessageHandler.java:385)
at org.eclipse.ajdt.internal.ui.ajde.UIMessageHandler.access$2(UIMessageHandler.java:375)
at org.eclipse.ajdt.internal.ui.ajde.UIMessageHandler$1.run(UIMessageHandler.java:259)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2326)
at org.eclipse.ajdt.internal.ui.ajde.UIMessageHandler.showMessages(UIMessageHandler.java:347)
at org.eclipse.ajdt.internal.ui.ajde.UIMessageHandler.showOutstandingProblems(UIMessageHandler.java:210)
at org.eclipse.ajdt.internal.builder.UIBuildListener.postAJBuild(UIBuildListener.java:205)
at org.eclipse.ajdt.core.builder.AJBuilder.postCallListeners(AJBuilder.java:1551)
- locked <0x00000000e12c4580> (a java.util.ArrayList)
at org.eclipse.ajdt.core.builder.AJBuilder.postBuild(AJBuilder.java:357)
at org.eclipse.ajdt.core.builder.AJBuilder.build(AJBuilder.java:270)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:728)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Attachment: 5664-6.txt
(Size: 25.01KB, Downloaded 66 times)
Attachment: 5664-7.txt
(Size: 24.08KB, Downloaded 68 times)
Attachment: 5664-8.txt
(Size: 24.09KB, Downloaded 60 times)
Attachment: 5664-9.txt
(Size: 24.33KB, Downloaded 52 times)
Attachment: 5664-10.txt
(Size: 24.32KB, Downloaded 74 times)
FUDForum. Page generated in 0.06729 seconds
