Home » Eclipse Projects » Remote Application Platform (RAP) » Dynamically Created Images in Tables
Dynamically Created Images in Tables [message #915735] Mon, 17 September 2012 17:41 Go to next message
Paul Watson is currently offline Paul Watson
Hi there,
What is the best way to go about displaying some dynamically created images in a table in RAP.
From the FAQ (http://wiki.eclipse.org/RAP/FAQ#How_to_display_dynamically_created_images.3F) it looked like I could create a BufferedImage, store it somewhere on the session store and retrieve it using a image service handler. I figured I could use the markup that is now supported for tables (and other widgets) to display the images).
However, when the images get displayed I get the following exception:
!ENTRY org.eclipse.rap.jface 4 2 2012-09-17 14:38:00.789
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.rap.jface".
!STACK 0
java.lang.IllegalArgumentException: Failed to parse markup text
at org.eclipse.swt.internal.widgets.MarkupValidator.validate(MarkupValidator.java:57)
at org.eclipse.swt.widgets.TableItem.setText(TableItem.java:261)
at org.eclipse.jface.viewers.TableViewerRow.setText(TableViewerRow.java:162)
at org.eclipse.jface.viewers.ViewerCell.setText(ViewerCell.java:162)
at org.eclipse.jface.viewers.ColumnLabelProvider.update(ColumnLabelProvider.java:36)
at org.eclipse.jface.viewers.ViewerColumn.refresh(ViewerColumn.java:155)
at org.eclipse.jface.viewers.AbstractTableViewer.doUpdateItem(AbstractTableViewer.java:399)
at org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRunnable.run(StructuredViewer.java:483)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:51)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:177)
at org.eclipse.jface.viewers.StructuredViewer.updateItem(StructuredViewer.java:2149)
at org.eclipse.jface.viewers.AbstractTableViewer.createItem(AbstractTableViewer.java:277)
at org.eclipse.jface.viewers.AbstractTableViewer.internalRefreshAll(AbstractTableViewer.java:757)
at org.eclipse.jface.viewers.AbstractTableViewer.internalRefresh(AbstractTableViewer.java:649)
at org.eclipse.jface.viewers.AbstractTableViewer.internalRefresh(AbstractTableViewer.java:636)
at org.eclipse.jface.viewers.AbstractTableViewer$1.run(AbstractTableViewer.java:592)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelection(StructuredViewer.java:1425)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelection(StructuredViewer.java:1386)
at org.eclipse.jface.viewers.AbstractTableViewer.inputChanged(AbstractTableViewer.java:590)
at org.eclipse.jface.viewers.ContentViewer.setInput(ContentViewer.java:280)
at org.eclipse.jface.viewers.StructuredViewer.setInput(StructuredViewer.java:1672)
at org.eclipse.nebula.widgets.pagination.PageLoaderStrategyHelper.loadPageAndReplaceItems(PageLoaderStrategyHelper.java:88)
at org.eclipse.nebula.widgets.pagination.table.PageableTable.refreshPage(PageableTable.java:217)
at org.eclipse.nebula.widgets.pagination.AbstractPaginationWidget.internalRefreshPage(AbstractPaginationWidget.java:347)
at org.eclipse.nebula.widgets.pagination.AbstractPaginationWidget.pageIndexChanged(AbstractPaginationWidget.java:269)
at org.eclipse.nebula.widgets.pagination.PageableController.notifyListenersForPageIndexChanged(PageableController.java:313)
at org.eclipse.nebula.widgets.pagination.PageableController.reset(PageableController.java:290)
at org.eclipse.nebula.widgets.pagination.AbstractPaginationWidget.refreshPage(AbstractPaginationWidget.java:319)
at com.arenasoft.bench.core.ui.views.EntityTableView.refreshTable(EntityTableView.java:219)
at com.arenasoft.bench.core.ui.views.EntityTableView.setInput(EntityTableView.java:112)
at com.arenasoft.bench.core.ui.views.DataWarehouseView.loadViews(DataWarehouseView.java:210)
at com.arenasoft.bench.core.ui.views.DataWarehouseView.access$4(DataWarehouseView.java:203)
at com.arenasoft.bench.core.ui.views.DataWarehouseView$OpenEntityTypeAction.run(DataWarehouseView.java:450)
at com.arenasoft.bench.core.ui.views.DataWarehouseView.doubleClick(DataWarehouseView.java:231)
at org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredViewer.java:828)
at org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(StructuredViewer.java:826)
at org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSelect(AbstractTreeViewer.java:1422)
at org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSelected(StructuredViewer.java:1228)
at org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEvent(OpenStrategy.java:242)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.java:239)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:304)
at org.eclipse.swt.internal.widgets.UntypedEventAdapter.dispatchEvent(UntypedEventAdapter.java:646)
at org.eclipse.swt.internal.widgets.UntypedEventAdapter.widgetDefaultSelected(UntypedEventAdapter.java:84)
at org.eclipse.swt.events.SelectionEvent.dispatchToObserver(SelectionEvent.java:194)
at org.eclipse.rwt.internal.events.Event.processEvent(Event.java:46)
at org.eclipse.swt.events.TypedEvent.processEvent(TypedEvent.java:186)
at org.eclipse.swt.events.TypedEvent.executeNext(TypedEvent.java:208)
at org.eclipse.swt.widgets.Display.runPendingMessages(Display.java:1145)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:1135)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2733)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2694)
at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:2530)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:702)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:685)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:157)
at com.arenasoft.bench.ui.application.rap.BenchApplication$1.run(BenchApplication.java:85)
at com.arenasoft.bench.ui.application.rap.BenchApplication$1.run(BenchApplication.java:1)
at javax.security.auth.Subject.doAs(Unknown Source)
at com.arenasoft.bench.ui.application.rap.BenchApplication.start(BenchApplication.java:44)
at org.eclipse.rap.ui.internal.application.EntryPointApplicationWrapper.createUI(EntryPointApplicationWrapper.java:38)
at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWTLifeCycle.java:177)
at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadController.run(RWTLifeCycle.java:289)
at java.lang.Thread.run(Unknown Source)
at org.eclipse.rwt.internal.lifecycle.UIThread.run(UIThread.java:101)
Caused by: org.xml.sax.SAXParseException; lineNumber: 1; columnNumber: 72; The reference to entity "imageId" must end with the ';' delimiter.
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(Unknown Source)
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.fatalError(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLScanner.reportFatalError(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLScanner.scanAttributeValue(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanAttribute(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(Unknown Source)
at org.eclipse.swt.internal.widgets.MarkupValidator.validate(MarkupValidator.java:53)
... 69 more
It seems the markup parser is failing with the html for the img (see the example given below). Is there something I am doing wrong, or is this a bug?
<img src="/rap?custom_service_handler=imageServiceHandler&imageId=m3738.png&nocache=1347917880977"/>
An alternative approach would be to simply write the images somewhere and make them available on the webserver (I will probably end up using using Jetty), then include a simple link to image in the markup. I am pretty new to Jetty, can anyone point me in the right direction to some information about opening up an image directory and interacting with that from RAP.
Many thanks,
Paul
Re: Dynamically Created Images in Tables [message #915896 is a reply to message #915735] Tue, 18 September 2012 03:08 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan Furnadjiev
Hi Paul,
looking into your image markup:
<img
I found two problems:
1. the '&' char in the src attribute, which is used as an HTML entity
start. Replace it with &amp;.
2. Missing mandatory image attributes width and height.
HTH,
Ivan
On 9/18/2012 12:41 AM, Paul Watson wrote:
> <img
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Dynamically Created Images in Tables [message #917018 is a reply to message #915896] Wed, 19 September 2012 14:38 Go to previous message
Doh!. Thanks for the help, should have seen that. Everything is working nicely now.
Paul
Previous Topic:CSS + Markup support for TreeItem
Next Topic:Session Recovery
Current Time: Fri May 24 09:50:33 EDT 2013
Powered by FUDForum. Page generated in 0.01581 seconds
