Home » Modeling » TMF (Xtext) » HOW DO YOU MODEL A DECIMAL? (I can't find a good way to construct a DECIMAL rule.)
HOW DO YOU MODEL A DECIMAL? [message #915322] Sun, 16 September 2012 23:48 Go to next message
JJ Missing name is currently offline JJ Missing name
I can't seem to find a way to model a decimal. These rules nearly work and I understand that there is an ambiguity with INT, but I am trying to create a decimal rule that would allow things like 0.1, 12, 23.234235 ...
terminal INT returns ecore::EInt:('0'..'9') | (('1'..'9') ('0'..'9')+ ) ;
DECIMAL returns ecore::EString : '-'? INT ('.' INT)? ;
POSINTNUMBER returns ecore::EString : INT ;
NEGINTNUMBER returns ecore::EString : '-' INT ;
INTNUMBER:
POSINTNUMBER | NEGINTNUMBER ;
Again I understand that my DECIMAL rule can evaluate to INT in the case of say '12', but it actually works. I do get the right value. The only time these rules don't work is when the value starts with '0' for instance 0.1 creates an error. I resulted in making sure INT would allow a single digit (see INT rule above), but that didn't change anything.
Could someone tell me what I am missing? Again, everything works perfectly except the case 0.XXX '12' and '23.234234' work just fine, negatives too, POSINT and NETINT work well.
thanks,
JJ-
Re: HOW DO YOU MODEL A DECIMAL? [message #915368 is a reply to message #915322] Mon, 17 September 2012 02:35 Go to previous messageGo to next message
If you're happy to model decimal as EString rather than EBigDecimal you
might just model aNumber and let the ValueConverters sort out the details.
Alternatively having INT return EString can give you more flexibility
over re-use again letting ValueConverters sort out the details.
[For OCL, where there are further ambiguities for e.g. "4..9" as a range
and "x.y" as a model navigation, the EssentialOCL grammar lies and
declares that a decimal is parsed as an INT, but actually a customized
TokenSource acts as a pre-lexer so that numeric '.' sequences appear to
Xtext as atomic tokens avoiding the need for clever disambiguation in
the subsequent rules.]
Ed Willink
> 23.234235 ...
> INTNUMBER:
> anything.
> thanks,
> JJ-
Re: HOW DO YOU MODEL A DECIMAL? [message #915453 is a reply to message #915322] Mon, 17 September 2012 06:02 Go to previous messageGo to next message
Henrik Lindberg is currently offline Henrik Lindberg
I use:
terminal INT : ('0'..'9')+;
REAL hidden(): INT ? '.' (EXT_INT | INT);
terminal EXT_INT: INT ('e'|'E')('-'|'+') INT;
Note that REAL is not a terminal.
I also don't associate value converters with these as there are other
places where I need INT, REAL etc as strings. So I also have:
RealValue returns ecore::EDoubleObject: REAL ;
Hope that helps.
- henrik
> INTNUMBER:
> thanks,
> JJ-
Re: HOW DO YOU MODEL A DECIMAL? [message #915507 is a reply to message #915453] Mon, 17 September 2012 08:38 Go to previous message
Ed, Henrik:
thank you very much for your reply.
I guess my DECIMAL rule was interfering with an array declaration '0..'
I did get it to go one step further with Henrik's suggestion and support .2 for 0.2, but I preferred replacing the a
Yes, I like/can make everything a String, this has worked best for me.
thank you again,
JJ-
Previous Topic:xtext + tycho + xtext-utils unit testing fails
Next Topic:semantic quick fixes and commens
Current Time: Sat May 25 23:24:16 EDT 2013
Powered by FUDForum. Page generated in 0.10233 seconds
