Home » Newcomers » Newcomers » an error occurred while automatically activating bundle org.eclipse.jdt.debug.ui(Error to lunch main ,in the Eclipse juno--)
an error occurred while automatically activating bundle org.eclipse.jdt.debug.ui [message #913144] Fri, 14 September 2012 17:19 Go to next message
franco umilio is currently offline franco umilio
I need help about a error that happens when you do run the project
I used indingo until yesterday without the problem
Today I decided to install juno but does not work
when do command run the following message appears:
Also if I go back to indigo does not work
can someone give me a help
I tried everything
I need for university
My S.O. is Ubuntu 12.04 --- open jdk 6 == jdk 6 e 7
Thanks from now
[Updated on: Fri, 14 September 2012 20:08]
Report message to a moderator
Re: an error occurred while automatically activating bundle org.eclipse.jdt.debug.ui [message #913212 is a reply to message #913144] Fri, 14 September 2012 21:42 Go to previous messageGo to next message
David Wegener is currently offline David Wegener
The latest Ubuntu open jdk upgrade breaks the Java timezone code.
See: https://bugs.launchpad.net/ubuntu/+source/openjdk-6/+bug/1047762
You can fix the problem by re-installing tzdata-java as mentioned in the bug.
Re: an error occurred while automatically activating bundle org.eclipse.jdt.debug.ui [message #913523 is a reply to message #913212] Sat, 15 September 2012 18:00 Go to previous message
Problem solve
I re-installing ""sudo apt-get --reinstall install tzdata-java"" ([b]Suggestion found in Ubuntu forum )
and work again ("Che Bello un allivio............")
Thanks to all for your attention and help
Sorry for my English,,,,,,,,,,,,,
Previous Topic:How to import ivy+ant project into eclipse juno
Next Topic:Do i need to download all the contents of the package in Eclipse Helios Sr2?
Current Time: Thu May 23 08:52:17 EDT 2013
Powered by FUDForum. Page generated in 0.01493 seconds
