Home » Newcomers » Newcomers » How to import ivy+ant project into eclipse juno
How to import ivy+ant project into eclipse juno [message #913421] Sat, 15 September 2012 15:53
Mahmoud Saleh is currently offline Mahmoud SalehFriend
this is my first use of ivy+ant and after building the project from command line, i want to import it into eclipse juno.
the project folder (trunk) contains the following folders/files:
- build
- dist
- src
- WebContent
- build.properties
- build.xml
- ivy.settings.xml
- ivy.xml
i tried to import the trunk folder that contains the above files/folder using import existing projects** into workspace, but i get the error that no projects found.
also i tried to configure the project for eclipse before importing using the following command:
ant eclipse-default
but i get the following error:
**Target "eclipse-default" does not exist in the project**
pleases advise how to import this project.
UPDATE 2: i was able to import the project in eclipse as follows
File > New > Other > Java Project From Existing Ant Buildfile
but when trying to run the project on server, i can't find run on server in the run options, please advise.
[Updated on: Sat, 15 September 2012 16:48]
Report message to a moderator
Previous Topic:Error while saving file
Next Topic:Going from Galileo to Juno
Current Time: Sat Jul 22 09:04:54 GMT 2017
Powered by FUDForum. Page generated in 0.03312 seconds
