Home » Language IDEs » CDT » includes/indexer issue when importing existing project
includes/indexer issue when importing existing project [message #913100] Fri, 14 September 2012 15:23 Go to next message
Christian Schlegel is currently offline Christian Schlegel
I have some trouble with a cdt c++ project imported from a git repo. When I import the project via Import... -> Projects from Git, the indexer is not able to resolve the "standard"/"built-in" includes and symbols. With standard I mean iostream and so on. Compilation works perfectly.
I put this down to the following. It can be reproduced with a simple c++ project via New -> C++ Project -> Hello World C++ Project (Linux GCC toolchain). After creation everthing is fine and the indexer is able to resolve the "standard" includes.
index.php/fa/11499/0/
But when I delete the project (not checking "Delete project contents on disk") and importing it again via Import -> Existing Projects into Workspace, the standard includes are missing/can not be resolved.
index.php/fa/11500/0/
This is the same with import from git repo. All manually added includes are resolved but not the standard ones.
Rebuilding the index and/or restarting eclipse brings no help. Am I missing something when importing an existing project? One workaround is to add the "standard" includes and symbols manually via Properties -> C/C++ General -> Paths and Symbols. But I think this could not be the final thing to do, as a new project does have these things already from some built-in mechanism.
I am working on Linux version 3.2.0-30-generic (buildd@batsu) (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) ) with Eclipse Modeling Tools Juno Release (build id: 20120620-1657) and CDT 8.1.0.201206111645.
I am open for any advice.
Christian
Re: includes/indexer issue when importing existing project [message #913117 is a reply to message #913100] Fri, 14 September 2012 16:17 Go to previous messageGo to next message
Klaus Mr is currently offline Klaus Mr
Member
check this settings (new in Juno):
http://wiki.eclipse.org/CDT/User/NewIn81#Scanner_Discovery
Check the FAQ also:
http://wiki.eclipse.org/CDT/User/FAQ
regards,
Klaus
Re: includes/indexer issue when importing existing project [message #913147 is a reply to message #913117] Fri, 14 September 2012 17:25 Go to previous messageGo to next message
Klaus Mr wrote on Fri, 14 September 2012 22:17
Thank you! Checking "Enable language settings providers for this project" did it. But now I am confused. It is checked on project creation. Why is it not checked after project (re)import by default?
Re: includes/indexer issue when importing existing project [message #913291 is a reply to message #913147] Sat, 15 September 2012 03:00 Go to previous message
Member
if you can reproduce it and if you think this is an error, than please make an error report. But first search through bugzilla (https://bugs.eclipse.org/bugs/), maybe someone else already has reported this.
If you report a bug or find an existing bugzilla bug entry please drop a short reply here to have this information immediately in this thread.
regards,
Klaus
[Updated on: Sat, 15 September 2012 04:34]
Report message to a moderator
Previous Topic:Undefined symbols for architecture x86_64: "_main", referenced from: start in crt1.10.6.o
Next Topic:Overview of indexer C++11 problems?
Current Time: Sun May 26 04:21:19 EDT 2013
Powered by FUDForum. Page generated in 0.01895 seconds
