Home » Modeling » TMF (Xtext) » ECore Double attribute does not show its name in content assist editor(Control-Space is not showing the name of my attributes of type ecore double)
ECore Double attribute does not show its name in content assist editor [message #913088] Fri, 14 September 2012 14:54 Go to next message
Duncan Krebs is currently offline Duncan Krebs
Member
I am trying to figure out how to get my xtext generated editor to show the variable/attribute name when pressing control-space, it works fine with INT, STRING, ID etc. but not with the ECore Double I have defined as the following in my grammer:
Anyone have any ideas how to get the contet assist to work correctly with this variable named 'balance' - Duncan
Account:
'Account' name=ID balance=DOUBLE;
terminal DOUBLE returns ecore::EDouble : '-'? ('0'..'9')+ '.' ('0'..'9')+ (('e'|'E') ('-')? ('0'..'9')+)?;
Re: ECore Double attribute does not show its name in content assist editor [message #913098 is a reply to message #913088] Fri, 14 September 2012 15:18 Go to previous messageGo to next message
Christian Dietrich is currently online Christian Dietrich
for custom things you have to define the content assist yourself.
Xtext does NOT reverseengineer terminal rules Wink
~Christian
Re: ECore Double attribute does not show its name in content assist editor [message #913136 is a reply to message #913098] Fri, 14 September 2012 16:58 Go to previous messageGo to next message
Member
Do you know what class I might want to look at to extend? - Duncan
Re: ECore Double attribute does not show its name in content assist editor [message #913142 is a reply to message #913136] Fri, 14 September 2012 17:12 Go to previous messageGo to next message
On 2012-09-14 20:58:38 +0000, Duncan Krebs said:
> Thanks, Do you know what class I might want to look at to extend? - Duncan
XXXProposalProvider - the class is already there
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: ECore Double attribute does not show its name in content assist editor [message #915587 is a reply to message #913142] Mon, 17 September 2012 11:36 Go to previous message
Member
Christian,
I tried figuring it out over the weekend the best I was able to get working was on control space for my DOUBLE attribute it hard coded the value instead of displaying the name of the attribute (maxLoss) like it normally does for other "built in" types like INT, ID and string, this is the code I added to my xxxProposalAdvisor
public void completeSurfStrategyType1_MaxLoss(EObject model, Assignment assignment, ContentAssistContext context, ICompletionProposalAcceptor acceptor) {
		super.completeSurfStrategyType1_MaxLoss(model, assignment, context, acceptor);
		String proposal = "MaxLoss" + "DOUBLE";
		acceptor.accept(createCompletionProposal(proposal, context));
Previous Topic:hidden whitespaces and formatting
Next Topic:Custom Content Assist
Current Time: Sat May 25 10:24:41 EDT 2013
Powered by FUDForum. Page generated in 0.01784 seconds
