Home » Eclipse Projects » Eclipse 4 » New Parts are not showed correctly
New Parts are not showed correctly [message #913052] Fri, 14 September 2012 13:05 Go to next message
Vincenzo Caselli is currently offline Vincenzo Caselli
Member
Frequently I see that a new Part added to the Application Model is not shown (but also happens with Menus/Commands/Handlers).
The problem can be solved adding the option
-clearPersistedState
to the Program Arguments (using the flag to Clear the workspace may not be an option since it erase any content of the runtime folder!).
Shouldn't it be good to add this option as a default for wizard "Eclipse 4 Application Project"?
Thank you
Vincenzo Caselli
RCP Vision
Re: New Parts are not showed correctly [message #913122 is a reply to message #913052] Fri, 14 September 2012 16:26 Go to previous messageGo to next message
Sopot Cela is currently offline Sopot Cela
You would need to file a bug for that: https://bugs.eclipse.org/bugs/enter_bug.cgi?product=E4&component=UI
Re: New Parts are not showed correctly [message #913176 is a reply to message #913122] Fri, 14 September 2012 19:16 Go to previous message
Member
Hi Sopot,
done!
https://bugs.eclipse.org/bugs/show_bug.cgi?id=389651
Previous Topic:Wizard "Eclipse 4 Application Project" possible new options
Next Topic:Wizard "Eclipse 4 Application Project" misses to add "org.w3c.dom.events" plugin
Current Time: Sat May 25 15:41:39 EDT 2013
Powered by FUDForum. Page generated in 0.02293 seconds
