| Remote debugging with eclipse [message #912829] |
Fri, 14 September 2012 05:05  |
donescamillo Missing name Messages: 12 Registered: September 2010 |
Junior Member |
I have Linux Fedora on my PC (in a virtual box, but that probably does not matter) and a Linux box (CPU=ARM), running Ubuntu for ARM.
I have a SSH connection between the two.
I cross-compile on Fedora, then send the binary to Ubuntu.
For debugging what I do now is put some code that writes in a log file on the ARM machine, then I inspect the file. That is slow.
Is there a way to run Eclipse in Fedora and to somehow configure it to do remote debugging on the code that runs on the ARM machine, like, setting breakpoints, inspecting variable values etc.
Thank you
FUDForum. Page generated in 0.01733 seconds
