Home » Eclipse Projects » Equinox » ssh console error: key_verify failed for server_host_key(ssh console error: key_verify failed for server_host_key)
| ssh console error: key_verify failed for server_host_key [message #912979] |
Fri, 14 September 2012 10:25 |
Tom Missing name Messages: 16 Registered: February 2010 |
Junior Member |
hello,
I've run into an issue trying to connect to the ssh console as described here: http://help.eclipse.org/juno/index.jsp?topic=/org.eclipse.platform.doc.isv/guide/console_shell.htm
Here is debug output from ssh client:
OpenSSH_4.1p1, OpenSSL 0.9.7d 17 Mar 2004
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: Applying options for *
debug2: ssh_connect: needpriv 0
debug1: Connecting to thehostname [xxx.xxx.xxx.xxx] port 8080.
debug1: Connection established.
debug1: identity file /var/myid/.ssh/identity type -1
debug1: identity file /var/myid/.ssh/id_rsa type -1
debug1: identity file /var/myid/.ssh/id_dsa type -1
debug1: Remote protocol version 2.0, remote software version SSHD-CORE-0.5.0
debug1: no match: SSHD-CORE-0.5.0
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_4.1
debug2: fd 3 setting O_NONBLOCK
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug2: kex_parse_kexinit: diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1
debug2: kex_parse_kexinit: ssh-rsa,ssh-dss
debug2: kex_parse_kexinit: aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,arcfour,aes192-cbc,aes256-cbc,rijndael-cbc@lysator.liu.se,aes128-ctr,aes192-ctr,aes256-ctr
debug2: kex_parse_kexinit: hmac-md5,hmac-sha1,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96
debug2: kex_parse_kexinit: none,zlib
debug2: kex_parse_kexinit: first_kex_follows 0
debug2: kex_parse_kexinit: reserved 0
debug2: kex_parse_kexinit: diffie-hellman-group1-sha1
debug2: kex_parse_kexinit: ssh-dss
debug2: kex_parse_kexinit: hmac-md5,hmac-sha1,hmac-md5-96,hmac-sha1-96
debug2: mac_init: found hmac-md5
debug1: kex: server->client aes128-cbc hmac-md5 none
debug1: kex: client->server aes128-cbc hmac-md5 none
debug2: dh_gen_key: priv key bits set: 136/256
debug2: bits set: 497/1024
debug1: sending SSH2_MSG_KEXDH_INIT
debug1: expecting SSH2_MSG_KEXDH_REPLY
debug3: check_host_in_hostfile: filename /var/myid/.ssh/known_hosts
debug3: check_host_in_hostfile: match line 5
debug1: Host 'myhostname' is known and matches the DSA host key.
debug1: Found key in /var/myid/.ssh/known_hosts:5
debug2: bits set: 501/1024
debug1: ssh_dss_verify: signature error
Setup is as follows:
Equinox 3.8
JRE 1.7
On Windows 7
Eclipse product build using windows 32 bit launcher
Any ideas how to troubleshoot this or how to fix?
T
Current Time: Thu May 23 02:21:55 EDT 2013
Powered by FUDForum. Page generated in 0.01750 seconds
