| Missing min/maximize buttons [message #912582] |
Thu, 13 September 2012 15:57 |
Suma Rao Messages: 3 Registered: September 2012 |
Junior Member |
Just started building an Eclipse RCP application. I am using the latest Juno Release. I created a plug-in project and later added a product configuration to run it as an rcp application. I also added a perspective and 3 view parts. Added these view parts to the perspective and when I run the application I do not see the min/maximize window icons for any of the 3 view parts.
Is this normal? I tried explicitly setting setFixed(false) on the layout in my perspective and layout.getViewLayout("viewid").setCloseable(true); When I run, the min/max icons just don't display and I see a blank/missing border in the top right corner of all the views.
Any suggestions on how to fix this? Should I not use Juno since I am not using any of the E4 features and switch back to Indigo? Could this be the issue here?
Thanks. Any suggestions?
SumaR
[Updated on: Thu, 13 September 2012 15:58] Report message to a moderator
FUDForum. Page generated in 0.01590 seconds
