| Re: Failed to open the report document [message #911832 is a reply to message #909749] |
Wed, 12 September 2012 08:09   |
sidharth mv Messages: 9 Registered: July 2012 Location: India |
Junior Member |
Hello Jason,
Thank you for your suggestions and insights. It worked well.
Kudos..!!!
I did it in this way...
For caching the report>> context-path/frameset?__report=report.rptdesign&__document=report.tptdocument
And to render the cached report>> context-path/run?__document=report.rptdocument
It was great!!
And,
1. Is there a way to setup a cronjob to run this caching? Because the report needs to be refreshed, may be in every hour. If yes, how?
2. For over writing the rptdocument, 'context-path/frameset?__report=report.rptdesign&__document=report.tptdocument&__overwrite=true' will work?
Sidharth
[Updated on: Wed, 12 September 2012 09:30] Report message to a moderator
FUDForum. Page generated in 0.03400 seconds
