Home » Modeling » Graphiti » Redraw widgets for different types of input in Properties view
Redraw widgets for different types of input in Properties view [message #912329] Thu, 13 September 2012 07:06 Go to next message
navlelo Mising name is currently offline navlelo Mising name
I have a diagram with different nodes which have different properties. I want to show these properties in the Properties view, but to do this I need to redraw all the widgets for each node. I have looked into ISectionDescriptorProvider and ISectionDescriptor. However, I can't find a way to assign a ISection to a certain type of pictorgram element (or rather the businessobject underneath).
How do I do this?
Re: Redraw widgets for different types of input in Properties view [message #912348 is a reply to message #912329] Thu, 13 September 2012 07:50 Go to previous messageGo to next message
Michael Wenz is currently offline Michael Wenz
The Graphiti tutorial has a tabbed properties section that uses a filter
class to show it for EClass domain objects only. That should be what you are
looking for.
Michael
Re: Redraw widgets for different types of input in Properties view [message #912372 is a reply to message #912348] Thu, 13 September 2012 08:55 Go to previous message
As far as I can tell, that filter does not do what I want. Through the filter I get the selected object, but the select method only returns a boolean. To call the createControls method on the ISection, I need a Composite object, as well as a TabbedPropertySheetPage. These are not passed through the filter.
I want to dynamically create the widgets based on the shapes contained in my diagram elements.
Previous Topic:Handling business objects shared among different diagrams
Next Topic:Expose DefaultUpdateBehavior.workspaceSynchronizer to Extenders
Current Time: Sun May 19 23:52:34 EDT 2013
Powered by FUDForum. Page generated in 0.01570 seconds
